E36 (1991 - 1999)
Old 10-01-2012, 01:18 PM
flyboy1247 flyboy1247 is offline
Mein Auto: 1994 325is
ABS/Traction Control
1994 325is. My ABS and Traction Control lights come intermittently while driving. I just replaced the Wheel Speed/ABS Sensors, but I still have the same problem. What do I look for next?
Old 10-04-2012, 12:14 PM
Sorry my post is wrong. It is the ABS & ASC lights that are on.
Old 10-04-2012, 01:04 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Am I correct in assuming that you were experiencing these symptoms before you replaced the wheel speed sensors?
1998 BMW 328is
1966 Pontiac GTO
Old 10-04-2012, 01:40 PM
That is correct. That was the reason for replacing them. I corrected my earlier post. It is actually the ABS and ASC light rather than the Traction Control Light.
Old 10-04-2012, 02:08 PM
ZeGerman's Avatar
Warm Leatherette
In that case, provided everything is plugged in correctly, it's most likely a faulty ABS control unit.
1998 BMW 328is
1966 Pontiac GTO
Old 10-04-2012, 02:13 PM
Everything went back together just fine. Would a bad ABS unit cause the ASC light to come on?
Old 10-04-2012, 02:27 PM
ZeGerman's Avatar
Warm Leatherette
Yes, because the ASC system uses the ABS to modulate wheel spin.
Also, perhaps it seems too simple, but have you checked all related fuses and relays?
1998 BMW 328is
1966 Pontiac GTO
Old 10-04-2012, 02:42 PM
If a fuse or relay were bad, wouldn't the lights be on all of the time? They come on intermittently for no apparent reason. They come on sometimes when you apply the brakes, but they will also come while I am just driving down the highway.
Old 10-04-2012, 03:24 PM
ZeGerman's Avatar
Warm Leatherette
Yes, what you're experiencing does make it seem like a fuse or relay is not the issue, but they're worth checking nonetheless. Sometimes relays can get "sticky". But like I said before, if your wheel speed sensors are new and hooked up correctly, barring any fuse or relay issue, that pretty much only leaves the ABS control unit as the culprit.
1998 BMW 328is
1966 Pontiac GTO
Old 10-04-2012, 04:58 PM
I will check the fuses and relays first. Is there a test for the ABS Unit? I appreciate your help.
Old 10-04-2012, 05:17 PM
ZeGerman's Avatar
Warm Leatherette
I'm familiar with any kind of testing for the ABS unit, but others here may have some insight.
1998 BMW 328is
1966 Pontiac GTO
Old 04-07-2013, 01:31 PM
wheeler000 wheeler000 is offline
Mein Auto: 2003 330xi
all I can tell you is mine does the same thing
"I wrote them a letter that said I'll never come home, but did not send it and wrote it again and again; stacked up to the ceiling, and then another stack, and burned them all winter for heat."- Steve Albini
Old 04-07-2013, 08:03 PM
OV2310's Avatar
OV2310 OV2310 is offline
Mein Auto: 97 M3
Ive had the same problem since I got my car and havent had the chance to fix it but I'm going to test my sensors then deal with the abs unit if it doesnt get resolved.
I'll post an update with my solution for you and other people.
Sent from my SAMSUNG-SGH-I717 using Bimmer App
Old 04-07-2013, 09:06 PM
SCJon SCJon is offline
Poet of Signature Quotes
Mein Auto: 1997 BMW 328is
You could also take a look at the underside of the intake boot. There is an inlet there that vacuum line comes from underneath that plugs into the boot. That line controls the vacuum for ASC. If it is jimmied up somehow then the light could be intermittent with a vacuum leak coming and going? Just a thought and free to check.
"It doesn't do any good for me to know more than you if you aren't going to listen to me"
Originally Posted by petriej View Post
So let it be written, so let it be done.
Old 04-08-2013, 06:56 AM
mine magically stopped ...for now
