Old 09-28-2012, 02:56 PM
DriftGirl DriftGirl is offline
SideShow activist
Mein Auto: 745Li
Soooo, I just finished Fixing my ( L7) Logic 7 amp....
Not sure I'd do it again if I had to
Ok, I'm a master @ Welding (I'd like to think so )...but Soldering!?!?!, not so much! I've done a sum in the past but nothing like this*
Anywayz, My L7 went out (subs only) a while back. I was going to send it off to the guy that everyone uses but figured I'd try it myself after seeing the DIY instructions posted by "PAPER"
Got a hook up on the parts I needed...I wish I had taken the rest, but silly me just got what I needed.
What i'm trying to figure out now is the best way to mount the new chips to the amp body.
Lets just hope the car doesnt catch fire now!
*small Asian hands help!
Current Lineup:
BMW E31: Air suspension,19x10 / 19x11 Trafficstar
BMWE38:Air suspension,20x10 / 20x12 Forgiato (SOLD)
BMWE65: 22x10 / 22x11 Asanti ELT (SOLD)
Lexus SC400: Single turbo, 19" SRR wheels
Lexus GS300: VIP , Air Suspension,19" WORK wheels
S13 Silvia: WideBody, JDM conversion,SR20det,15" WORK wheels
Lexus LS430 UL:Air Suspension, 20"MAYA DLS
Old 09-28-2012, 04:04 PM
olegmedinskiy olegmedinskiy is offline
Mein Auto: 04bmw745lis 02bmw325conv
I drill a holes and put them on bolts pluss don't froget to use thermal paste between chip and l7 box also good idea to put some radiators on other side to make heat sink to cool off chips. Also is your cooling fan works?? If not you need to fix thet to
Sent from my HTC VLE_U using Bimmer App
Old 09-28-2012, 04:26 PM
SideShow activist
Mein Auto: 745Li
thank you sooo much!
I'll look into the fan, worst case ill just throw in a relay to power it when music is played.
Off to the store to get paste!!
Current Lineup:
Old 09-28-2012, 05:13 PM
samadkins29's Avatar
samadkins29 samadkins29 is offline
Mein Auto: '03 745Li
Any chance you could post a pic or type out how to remove the L7 amp? I start n every time I end up giving up. I must be doing something wrong, it just seem to hard to get it out.
Old 09-28-2012, 05:26 PM
It's easy take the left side of the panal and pull 2 metal rods under the l7
Old 09-28-2012, 07:54 PM
SFbay SFbay is offline
Account Under Review
Mein Auto: BMW 745i
Hmmm....
And you are a female??? With lots of soldering experience?? Wow, now I feel embarrassed
Good job!
Old 09-28-2012, 08:13 PM
SideShow activist
Mein Auto: 745Li
Got the paste and dug up sum nuts n bolts i had laying around.
Jus marked off the drill spots and headed to the garage to mount the lil chippers on the chassis...thanks "olegmedinskiy!
Current Lineup:
Old 09-29-2012, 09:31 AM
Driftgirl did it work it looks on your picture wiers to long I mede my like
1 inch.
Old 09-29-2012, 11:09 AM
Mein Auto: BMW 745i
1 inch.
Almost in English or hangover from Friday night ?
Old 09-29-2012, 11:35 AM
SideShow activist
Mein Auto: 745Li
They are a little long, but it allowed me to move them a bit for mounting below the upper circuit board.
Current Lineup:
Old 09-29-2012, 12:06 PM
pmpn8ez's Avatar
pmpn8ez pmpn8ez is offline
Mein Auto: 04 BMW 745Li E66
What do you have to do to fix the L7?
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Spacers 20mm Front 30mm Rear
Akebono Brake Pads
JL Audio 500/1 Amp
2 Type R 10" Subwoofers
Old 09-29-2012, 01:09 PM
Hope it works if you need to know how to fix fan let me know I have some pictures and capacitors.
Old 09-29-2012, 01:24 PM
Old 09-29-2012, 06:54 PM
SideShow activist
Mein Auto: 745Li
PAPER posted a DIY in the DIY section
Thank you si much! Youve been a great help
I picked up a 12v fan controller that I'll just run to the fan via a relay. I thought about wiring a temp sensor but thats probably overkill. It will just run whenever the amp powers up.
Thanks again!!!!
Current Lineup:
Old 09-29-2012, 08:05 PM
KingSilverback KingSilverback is offline
The Silverback
Mein Auto: 2006 750Li
I wish my girl was as tech saavy as you DriftGirl lol when are you plugging the amp back in the car?
Old 09-30-2012, 11:08 AM
Mein Auto: BMW 745i
Thanks again!!!!
But what about original transistors
Bipolar one?? Simply bypass it using same +12v intended for chips? Originally it's controlled via CPU on the upper board.
Isn't it easier to use existing high tech logic instead?
Also don't forget about head ask unit. It's gonna die if you like it loud
Old 10-01-2012, 02:57 PM
SideShow activist
Mein Auto: 745Li
Was thinking...has anyone ever tried to reflow the circuit board? I could be wrong...as usual but Reading thru many post where I find people are experiencing the amp working fine and then having sub channels go out within minutes.
I SUSPECT its the fan that goes first and the board is a victim of poor solder or cold solder spots that lose contact as soon as it heats up a bit.
I dunno, one day I'll grab a broken one off the bay and see what happens if I re-flow the board.
The way I did this was the quickest for me without trying to re-engineer the Amp...above my skill level
oh, ASK unit is sounding "scratchy"...this car is getting on my nerves now! LoL!
If it has any static next month....the entire audio system is going Aftermarket
Current Lineup:
Old 10-01-2012, 03:35 PM
Mein Auto: BMW 745i
Aftermarket sounds crazy in e65
You're gonna lose pretty much all e65 toys: navi, pdc, voice control etc.
So fix the ask unit as you did with L7.
