Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series
6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations.
Old 10-01-2012, 07:43 PM
IL_BMW_650 IL_BMW_650 is online now
Mein Auto: 2007 BMW 650i
LED front and rear turn signals
New member here with a 2007 650i coupe. I've always liked the LED front and rear turn signals that came on the 2008+ 650i/M6. I am assuming to get the same look, I'd have to find 2008+ OEM turn signals (front and rear) or is it as simple as replacing my bulbs with LEDs?
thanks in advance!
2007 BMW 650i | monaco blue | sport package | cold weather package | comfort access | HUD | 6-speed manual
Old 10-02-2012, 11:34 AM
pablo645's Avatar
pablo645 pablo645 is offline
Mein Auto: 650i Convertible
Welcome IL_BMW_650. So in regrads to your question, you have to replace the lights. The rear is simple enough but the front depends on if you want to replace just the turn signal section or the whole headlight. The rear I believe you can just buy a new set along with an adapter cable to prevent flickering in the LEDs (search for this on this forum) The front LED turn signal assembly will also require some wiring modification to work as well. This too was done by members here just do a seach. So to put simply you would need new lights not just bulb replacement.
2008 650 Convertible- 6 Speed manual- Sport package- HUD- Lane Departure- Comfort Access- Merino Leather- HD Radio- SAT
Old 10-02-2012, 12:21 PM
thanks for the response Pablo. yeah, I would only want to replace the front turn signal to the LED version. Would the 2008+ front LED turn signal just be a simple plug and play solution?
Old 10-03-2012, 12:02 PM
prospect500 prospect500 is offline
Mein Auto: '05 645Ci
Welcome to the board!!!
Here are links from the M6 Board forum below:
2006 M6 Turn signal upgrade to 2008 LCI LED turn signals
http://www.m5board.com/vbulletin/e63...n-signals.html
2006 M6 tail light upgrade to LCI LED's.
http://www.m5board.com/vbulletin/e63...-lci-leds.html
There is some good info there and here as well if you do a search.
I too want to do this mod to my '05 but only the turn signals in the front and full tail lights and from what I gather you need adapters in the front and rear.
The LCI fronts are expensive ($2000.00+ expensive)....
Old 10-03-2012, 05:18 PM
tampamark tampamark is online now
Mein Auto: 2006 650 convertible!!!
Here is a thread for you to review, while Dan (whatheheck) on the M5Board bought adapter cables I believe, the guy in this thread shows a DIY for wiring yourself.
http://www.bimmerfest.com/forums/sho...ght=led+wiring
Old 10-03-2012, 08:19 PM
thanks guys, I'll be sure to check these out!!!
