Door lock issue - Bimmerfest - BMW Forums
Old 09-30-2012, 09:21 AM
Tiko530 Tiko530 is offline
Mein Auto: 2003 530i
Door lock issue
Took a few hours to sand, buff and polish my headlights yesterday, ended up with good as new headlights but now I have a new headache to worry about. My driver door will not lock. Everytime I press the lock key in the middle panel or lock/unlock on my key I hear a whirring noise coming from te lock area but the piece won't go up or down and the door remains unlocked. I suspect (after doing a search here) that it's the actuator but didn't find any threads that referenced the whirring noise so I was hoping someone could confirm for me that that is the issue before I take the door apart.
Old 09-30-2012, 02:53 PM
I followed instructions in the first thread of this forum and typed /door lock actuator F3 in the bestlinks, which found this, which has a lot of pictures:
- How to properly maintain a door lock (1) & a DIY for how to replace the front lock door actuator (1) & how to disable automatic door locks (1) (2)
Old 09-30-2012, 06:56 PM
Thanks for the concise info, so I'm gathering that it is indeed the door lock actuator that needs replacement based on the description and the noise and not some other piece that needs repair or replacement
Old 10-01-2012, 01:02 PM
john@eac john@eac is offline
Past Sponsor
Mein Auto: Many
If you find that the actuator is the problem take a look here and at least check our prices.
http://www.eaceuroparts.com/parts/pa...ge/31/2003/374
Old 10-01-2012, 02:23 PM
Fudman's Avatar
Fudman Fudman is offline
STOP EVERYTHING!!! The whirring noise is the death knell of your actuator. You definitely have a failing actuator. DO NOT ATTEMPT TO LOCK YOUR DOOR UNDER ANY CIRCUMSTANCES!!! See my thread about the DIY door actuator just posted. If you lock your door, it may not unlock. Then you are truly stuck up the creek without a paddle. You will have to cut into or destroy the door panel to open the door to effect a repair. Fix it immediately or you are screwed!
Old 10-01-2012, 04:19 PM
540 M-Sport's Avatar
540 M-Sport 540 M-Sport is online now
Mein Auto: 01' 540 M-Sport, Scuderia
Make sure to clean and lubricate the lock and latch mechanism, to ensure logevity of the replacement actuator.
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, M5 rear subframe braces, H&R 15mm wheel spacers, ST X (KW) coilovers, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, USA Spec Ipod/Iphone integration.
Old 10-01-2012, 08:35 PM
Thank you guys, Fudman I read your thread earlier and was definitely worried so I have yet to lock the door, I appreciate the warning as well. Did my Vanos seals today, it took me so long I didnt get a chance to even pop the door open to inspect, will update when I open it up.
