Old 08-16-2012, 10:51 AM
e39540iv8 e39540iv8 is offline
Mein Auto: 2000 BMW 540iA
DIY Alternator Bearing Replacement
If the alternator bearing is causing a belt noise issue I'm pretty sure the alternator doesn't need to be replaced only taken apart and the bearings replaced. I say this because parts are so expensive and with some DIY costs can be saved. Check this video out, I know it's an M5 but you get the idea.
Check out around 22:00
Old 08-16-2012, 11:42 AM
mbell666 mbell666 is offline
Mein Auto: e39 2002 540i6
Later 540i have a water cooled alternator that is different to the alternator shown. It probably possible to just replace the bearing in that aswell, but probably trickier and more expensive. Also mean messing with coolant system.
An e39 is like a beautiful wife, needs constant attention, lots of money, lets you down at the worse times but youd never be without it.
Old 08-16-2012, 01:16 PM
Aww I didn't know that. God this car has turned out to be a nightmare for me. Anyways it's a cool video. I like how cheap cars are in the UK, he bought an M5 for less than what I bought a 540i here
Old 08-16-2012, 01:19 PM
540indiana's Avatar
540indiana 540indiana is offline
Mein Auto: 2000 540i Sport
Mine belt is slipping too. Also noticed my alternator moaning.. All because of procrastination by not fixing the ps leak..
Old 08-16-2012, 02:16 PM
When petrol (gas) is ~$8.50 a gallon, road tax is about $800+ and insurance is about 5-10% of your income cars like this don't cost a lot to buy. I could have bought my 540i for half the price or less in the UK.
Generally cars over there have lot lower second hand values, you can get a very usable car for $600 ish. I think a lot of it is because they are right hand drive so limit market and they can't be export easily, unlike other bits Europe.
Old 08-16-2012, 03:06 PM
This may be useful ...
- How to test your generator (1) & how to determine exactly what alternator you have (1) & a DIY for replacing the E39 I6 alternator (1) (2) (3) (4) (5) or E39 V8 alternator (1) (2) (3) (4) & why you want to clean out the air-cooled alternator air duct & cooling vents (1) (2) (1) (2) & why rebuilding an alternator is preferable to replacing (1) & cn90 DIYs for rebuilding a 1998 air-cooled BMW Bosch alternator (1) (2) or his VW Bosch alternator (1) & cdawg246's quest for materials for a Bosch water cooled alternator rebuild (1) & Aioros' 1999 Valeo Alternator rebuild DIY (1) and his quest for materials (1) & Cn90's explanation of where to get hard-to-get alternator rebuild parts (1) & how to tell from the part number if a replacement alternator is actually rebuilt "by" Bosch (1) & a DIY for replacing the brushes in an (Audi) Valeo alternator (1) & a Bosch alternator bearing replacement from a 1997 MB S600 (1) & from a Range Rover (1).
Old 08-17-2012, 07:54 AM
What's the PS leak?
Old 08-17-2012, 08:03 AM
dvsgene dvsgene is offline
Search, Read, THEN Ask
Mein Auto: 98 540i M62 3.15
What's the PS leak?
(P)ower (S)teering Leak. Two hoses above the alternator leading from the Power steering reservoir.
Old 08-17-2012, 10:19 AM
What's the PS leak?
+1 to what dvsgene said.
I went to the bestlinks and typed /power steering F3 and found this, among others:
- Why you want to fix the power steering hose drip onto the alternator (1) (2) (3)
Old 09-03-2012, 06:52 PM
Pksnake Pksnake is offline
Mein Auto: 2002 540i
Water cooled alternator
Hello all, I'm new to bimmerfest. I've owned my 02 540i for 2 yrs. my bearings in the alternator sound shot. It is water cooled. I'm looking for info on how this is removed. It does not look like a usual alternator. Any advice
Old 09-03-2012, 06:55 PM
Welcome to the forum.
Links in my signature is a great start to navigate the forum and find the various DIY write-ups.
If you still can't find it, let us know and someone will guide you the first few times.
Old 09-03-2012, 07:09 PM
pleiades pleiades is offline
Mein Auto: '99 5-spd
Here's the BMW TIS procedure (scroll halfway down the page...)
http://tis.spaghetticoder.org/s/view.pl?1/00/13/25
Old 09-04-2012, 06:35 PM
Thanks for the info. It will take me a bit to become familiar with the site. I am having a bear of a time of removing the Torx screw from the tensioner pulley. Any suggestions? The Torx pattern is becoming stripped.
Old 09-04-2012, 06:45 PM
Unless the bolt is seized, it really shouldn't take much effort to remove. IIRC. it is a T50 torx head. When using a smaller size Torx, they tend to strip.
Old 09-05-2012, 07:00 AM
caryalon caryalon is offline
Mein Auto: 2002 530i, 2001 325i
You don't remove the Torx screw from the tensioner pulley. You rotate the tensioner pulley (clockwise) to remove tension from the belt so you can slip the belt off, then (slowly) release the pulley to rest. When you install the belt, you do the same.
Old 09-05-2012, 07:06 AM
While this may be true on the I6-528i, this is not true on the V8-540i or the I6-530i.
I've removed ALL 3 pulleys before when I replaced them with DAYCO rebranded INA pulleys/bearings for $8ea. Saving close to $100 from having to buy the whole assembly. Plus the replacement DAYCO was made of steel not polymer plastic.
Old 09-05-2012, 07:37 AM
I have no personal experience with the V8, but the 2.5 and 3 liter I6 engines both use a tensioner pulley as I described. I guess I shouldn't be surprised that the V8 would be different.
Perhaps I misunderstood - I wasn't talking about replacing the tensioner pulley itself, just using it to remove/replace the belt.
Do you have DAYCO part numbers? That would be good to file away for future use... Thanks!
Old 09-05-2012, 07:52 PM
I haven't had success removing the t50 bolt from the pulley. I'm afraid to report donkey, this would be me, has officially stripped the torx. I'm thinking of cutting the plastic pulley off and place vice grips on the outer diameter of the t50 bolt and whack the crap out of it to try and crack it loose.
Old 10-01-2012, 07:10 PM
Update... A few weeks ago I had a buddy weld a nut to the Torx bolt head. This worked well. The bolt loosened and the alt replacement went well.
