E46 (1999 - 2006)
Old 10-02-2012, 03:50 PM
tamlee272 tamlee272 is offline
Mein Auto: 2002 bmw 325 x1 sedan
outside ambient temp sensor
ok guys its the bimmer virgin again. i got the inner fender and hardware and ambient temp sensor. i also got the plug that connects to the sensor. my question which is prob a stupid one is what size are the barrel pins that go in the plug. the ends you crimp to the wires? all advance had was 5/32 and i know they were way too big. i figured the plug would come with this pins. i tried to slide the wire in to see if it was the lock type but a no go. thanks again for your patience i am learning but it is my first bimmer
Old 10-03-2012, 05:27 AM
Hellpuppy Hellpuppy is offline
Member: Church of the FSM
Mein Auto: 323Ci 911 914 996 F-150
If I understand you, the temp sensor came without crimp connectors? If so, best to solder it on because the sensor circuit is very sensitive to resistance and a homemade crimp connection will just cause you trouble down the road.
Old 10-03-2012, 11:06 PM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
Crimp connection is not home-made.
My company builds equipment with them for decades.
Solder is always cool too.
