E36 (1991 - 1999)
Old 10-02-2012, 05:18 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Anyone Had Power Brake Booster With a Vacuum Leak?
I think I may have a vacuum leak in my brake booster. I have a turbo like whistle I can hear better from inside the car than from the engine compartment, I have power boost to the brakes but the effort feels higher than it should (definitely higher than my E46 by comparison), and when I hook my vacuum gauge directly to the manifold I get 19", but when I tee in with the brake booster connected in I get 17"-18". Also when I apply the brakes with the vacuum gauge teed in I get a vacuum drop (expected) but it takes several seconds to build back up to 17".
Anybody had this before?
I've sprayed brake cleaner all around the intake manifold and the associated hose connections without any vacuum leak associated signs, but the "turbo whistle" persists.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 10-02-2012, 06:02 PM
Echo46 Echo46 is offline
Mein Auto: 2006ZCP M3and 1999 M3vert
Have you inspected the intake manifold adjuster-DISA Valve- for leak and/or functionality?
Old 10-02-2012, 06:42 PM
drivinfaster's Avatar
drivinfaster drivinfaster is online now
Mein Auto: rescued bmw's
disconnect the vac feed to the booster, block it off, and see if vac increases. if it does, then suspect a leak.
if you have a vac pump, you could also use an adapter to fit the inlet, and then apply vacuum. if it holds, then no leak. if it does not hold, suspect a leak.
df
Old 10-02-2012, 06:44 PM
dc_wright's Avatar
I would if I had one. It's a 328, not a 318.
Old 10-02-2012, 06:46 PM
df
Old 10-02-2012, 06:51 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
^I thought only 318s had DISA valves, too.
1998 BMW 328is
1966 Pontiac GTO
Old 10-02-2012, 07:00 PM
dc_wright's Avatar
df
I probably wasn't clear in my OP. When I disconnect the vac feed to the booster I get 19". When I tee into the vac feed line so that it's connected to the manifold and the booster is when I get 17"-18".
I've got a mighty Vac and when I connect it to the booster hose I don't think I've been able to get the one way valve to open so I think I've only been testing the hose......I may just have to pump the crap out of it for a while to verify I've got it really evacuated.
Old 10-02-2012, 07:12 PM
a smoke machine would also work, but not many of us have those...
if it leaks, it's visible.
df
Old 10-02-2012, 07:31 PM
dc_wright's Avatar
I think it may be the grommet where the one way valve plugs into the vac booster. When I tried pumping it down when the hose was connected to it I couldn't get it to hold anything. I popped the one way valve out along with the hose and pumped it down to 25" no problem. I plugged it back in and with a crap load of pumping with the MightVac it pumped down to 20" and seems to be holding. I'm going to let it sit there for a while and see if it held.
Old 10-02-2012, 07:38 PM
some rtv around the grommet may help. at least until a new one can be delivered.
df
Old 10-02-2012, 08:05 PM
dc_wright's Avatar
Held for 20 minutes no problem. I'm going to order the grommet, the one way valve, and the hose and see if that does the trick.
