N52N 2007; interpreting some codes - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 10-02-2012, 05:29 PM
Saintor's Avatar
Saintor Saintor is offline
Abuser of everything
Mein Auto: BMW-less for now
I have 2 codes
2A17 DMTL System fault (or leak according to Bentley)
29CE Combustion misfire.
The symptom is after 1-2 minutes after some cold starts, you can feel the engine misfire. Restart and immediately the symptom is gone.
Would replacing this likely to solve the 1st one?
http://www.ecstuning.com/Search/16137193479/
For the 29CE, can it be a coil?
http://www.ecstuning.com/Search/12137594937/
What would be the next logical steps?
