E36 (1991 - 1999)
Old 10-02-2012, 07:28 PM
Hatterer4's Avatar
Hatterer4 Hatterer4 is offline
Mein Auto: 1993 BMW 318is
vacuum woes
so my 93 318is has a idle issue. i started the car and took off the oil filler cap with ease. Idle increased and sounded better. I unplugged the vacuum line the run from the valve cover to the throttle body, and also had a slight increase. When I plugged the tb and vc hose in the idle surged and was bouncing for about a minute and same with the oil cap. I tried to pull the oil dipstick, but that mofo is not coming out. I've checked for vacuum issues constanly and repaired them. Still no idle fix. Ideas?
Sent from my SCH-I405 using Bimmer App
Old 10-03-2012, 05:30 AM
Echo46 Echo46 is offline
Mein Auto: 2006ZCP M3and 1999 M3vert
Clean the ICV and throttle body. Did you check the intake boots for cracks. Are the plugs clean and check your coils. You might want to change the fuel filter.
Old 10-03-2012, 09:42 AM
Hatterer4's Avatar
Brand new icv tb clean intake boot 4 months old plugs are clean and no. How would I test it? And the idle it bad when I have the headlights on. But the idle only happens when its warm. And napa is getting me a fuel filter soon along with a heater core.
Old 10-03-2012, 04:16 PM
I'm confused. Do you have the idle issue on a cold start or on a warm start or after car warms up and is running.
Old 10-03-2012, 05:40 PM
Hatterer4's Avatar
Only when the car is warm and is running.
Old 10-03-2012, 06:11 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
i'm concerned about the change when the lights are on. get your charging system checked out.
df
Old 10-03-2012, 06:33 PM
hornhospital's Avatar
D'oh, You Kids!
df
^ this, for sure. That's not normal at all.
Quotes to live by:
Old 10-03-2012, 06:37 PM
Hatterer4's Avatar
So do you think maybe battery or alternator? And it does runs little low when I'm driving without lights on. Only when it's warm it runs low and wants to stall
Old 10-04-2012, 05:02 AM
I agree, check the alternator.
Old 10-04-2012, 05:16 AM
Hatterer4's Avatar
well the alt was replaced in may so i hope its not that but ill check. its probably going to the shop on 10/5/12 (tomorrow) or Monday 10/8/12
Old 10-04-2012, 10:16 AM
bmw-mania bmw-mania is offline
Mein Auto: BMW
If you take to shop.. why pose question?
Originally Posted by cj.surr View Post
I don't have to read the username on these posts to know who wrote it.
Bmw-Mania, Ladies and Gentlemen.
Old 10-04-2012, 03:20 PM
Hatterer4's Avatar
Old 10-04-2012, 03:21 PM
Hatterer4's Avatar
I don't wanna guess and spend more money where the shop can test it and tell me what's wrong.
