Old 10-19-2014, 05:44 PM
aioros aioros is offline
aioros
Mein Auto: 99 528i auto m-sport susp
evap purge valve, p0441 not fix
i replaced the evap purge valve a couple of days ago due to a constant p0441 code. unfortunately, the new valve did not care of the "incorrect purge flow"
anyone with what would the next thing to check or replace?
Old 10-19-2014, 05:57 PM
JDeGraff89's Avatar
JDeGraff89 JDeGraff89 is offline
Otto Zwei-Punkt-Null
Mein Auto: 12- 2002 530i Auto,
Hmmm vaccum hose seems logical? If its a vaccum controlled valve?
Current: 12/16/2002 530i Auto Titangrau/Standardscwarz
R.I.P. Otto, 04/17/97 - 02/02/15 You'll be missed my drunken Bavarian friend.
"Owning one of these cars is much like owning a two year old child. It's annoying most of the time, but if anyone tries to take it from you'll kill them." J. Clarkson.
Old 10-19-2014, 06:57 PM
aioros
im not 100% sure how it really works...yet. gas fumes go to the charcoal canister then pump to the intake. the purge valve opens to let those fumes go to the intake manifold.
Old 10-19-2014, 07:31 PM
JDeGraff89's Avatar
I'm geussing then vaccum. But I am also not sure, someone who knows should stop in shortly.
Old 10-19-2014, 08:11 PM
cn90 cn90 is offline
Was the 1-way valve re-installed correctly?
Old 10-20-2014, 04:52 PM
kenr88 kenr88 is offline
Mein Auto: 2013 535l F10
aioros, you were part of my original thread on this. Although this valve fixed my incorrect purge flow problem (I guessed it was stuck in the open position) and a multiple misfire issue, had it not, I would have started with the electrical signal next. I had already inspected the vacuum lines and was pretty confident there was no vacuum leak.
I'm sure you must have already checked you gas cap as this is most common. I would first check the system at the driver-side rear wheel well for any broken vacuum lines or connectors. Then the passenger side rear wheel well for integrity in the fueling system. After that, I would then look that the valve is being receiving the right commands
2013 535i N55 6-cyl Turbo
4 door sedan
Turlock, CA
Old 10-20-2014, 10:04 PM
aioros
aaaah yes.
Old 10-20-2014, 10:05 PM
aioros
i will check all the hoses again
