Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 10-03-2012, 01:46 AM
tim96 tim96 is offline
Mein Auto: bmw e30 320i
pulsing (not surging) at idle?
the rev gauge stays constant , but sometimes when i start my e30 it feels like it's pulsing rather than a smooth idle, the exhaust sounds like it's pulsing , sometimes the car gets a shake to it as a result of the pulsing. My engine mounts are not broken.
other stuff which may or may not be related, the other week i suspected it is running rich due to strong exhaust smell, if I quickly open the throttle with my hand it will dip and nearly cut out before the revs increase.
I am thinking vacuum leak, engine temp gauge, fuel filter? I have a new air filter to put in it sometime soon. Any other ideas?
Old 10-03-2012, 01:55 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
Idle control Valve needs some cleaning I'd say
Don't take life too seriously; no one gets out alive !
Old 10-03-2012, 10:17 AM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 85' 335i
Sounds like your running rich.. I'd say replace that engine coolant sensor.
1985 335i
Black on Black coupe 5spd
Tokico lowering springs, KYB struts and shocks, BavAuto strut bars, SPC adjustable camber plates, Ireland Engineering rear toe and camber kit, Sparco buckets, Rota Torque 16x7 fronts 17x9.5 rear, Hella headlamps with HID conversion, all red taillights, MSD coil,M30B35 swap
http://www.bimmerfest.com/forums/sho...36#post7573736
M20B27 for sale in Cincinnati
Old 10-03-2012, 10:34 AM
BMWFatherFigure's Avatar
Old School
Check/change spark plugs and leads. Sticky valve?
Current:
Previous:
