Old 02-05-2016, 05:19 PM
Hurlin Hurlin is offline
Mein Auto: 2004 E60
Should I buy a 2004 E60 N62 6 speed?
Should I buy a 2004 E60 N62 6 speed, with 106k on it? It has a great service history, the owner now has a huge folder with all the maintenance records since he's had it (almost four years) and some from the previous owner. I am a DIY guy and my wife has been driving an 06 Mercedes C230 sport for the last four years and I have been the mechanic on it, and it's been great to have. I work in the auto industry as a painter in a body shop so I have a decent knowledge of the auto industry. Is there anything I should be looking for on the vehicle? It needs the bumpers painted which I can do easy, and a couple interior pieces repaired/replaced. I would appreciate any advice you can give me about this guys! Thanks in advance for the help. If I left anything out please let me know, as this is my first post here.
Old 02-05-2016, 05:21 PM
Mein Auto: 2004 E60
Also I have the carfax that shows a lot of service at the local BMW dealership.
Old 02-05-2016, 10:43 PM
Criper2000 Criper2000 is offline
Mein Auto: e60 535...
Look into if it has secondary air. If it does, the ports in the head get plugged and set a SES light. To fix, the heads have to come off. Also if there is a coolant leak at the weep hole, watch out. I have heard of an aftermarket fix to replace the water pipe, instead of taking the front covers off. Let the engine run warm up for a few minutes and then give it a quick hit to 4-5 grand on the throttle. Watch for smoke, if there is, the valve stem seals are bad.
Old 02-06-2016, 04:40 AM
banglenot's Avatar
banglenot banglenot is offline
Mein Auto: 2007 530
+1. Criper nailed it. These are three items that can make an N62 misery. That valve stem issue can be $3-5K to fix, and is not a DIY unless you're a very good amateur mechanic.
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
BMW CCA Member 10+ Years
Old 02-06-2016, 07:49 AM
Mein Auto: 2004 E60
Thanks for the replies guys. I'm going to go test drive it with my brother tomorrow so he will be able to help me look for smoke coming out of the exhaust. The price on it is 7k and has lower miles for the year, so I thought it would be a good buy. I absolutely love the look of the E60 and the manual transmission seemed too good to be true.
Old 02-06-2016, 07:56 AM
twh twh is online now
Mein Auto: 2006 530xi 6 speed
I gotta say that my 2006 530xi 6 speed is still a lot of fun. I'm sure the N62 is real fun to drive. If you are DIY and also have access to tools and labor and the car was maintained, and you are going in with your eyes open, I think it's probably a great car. The V8 biggies are noted and you should check if and when those have ever been done. They will have to at some point.
Old 02-06-2016, 08:08 AM
DBM550i DBM550i is offline
Mein Auto: BMW 08 550i Sport
Welcome and read this... http://www.bimmerfest.com/forums/sho...d.php?t=731460
David...
(oOO \ (||||)(||||) / OOo)
2006 325i
2006 M5
2008 550i
2008 X5 4.8i
A Few Other Vehicles/Projects
Old 02-06-2016, 08:52 AM
The reason they are off loading it, is 100k is when valve stem seal issues start show up. The aftermarket pipe is still about 800 just for the pipe.
Old 02-06-2016, 11:28 AM
Reino550 Reino550 is offline
Mein Auto: 2006 550i
Sometimes you won't see the smoke while driving, IME. Run it hard & hot for a good 10 miles at least. Then shut if off an wait at least an hour. Then start it up again--the smoke will be obvious if so.
Old 02-06-2016, 12:24 PM
07 E63650i's Avatar
07 E63650i 07 E63650i is offline
Freude am Fahren
Mein Auto: BMW E63 650i
Definitely check to service records to see how well maintained this car is.
Common issues with the N62B44 are:
Leaking gaskets(valve covers, upper timing covers, alternator bracket).
Coolant pipe seal(check the weep hole to see if there's coolant leaking out).
Valve stem seals(let it idle for 15-20 minutes and rev the engine to see if blue smoke comes out of the exhaust).
Secondary air system failure(common codes are P0491 and P0492).
Once a 6'er, always a 6'er.
