Old 10-02-2012, 05:00 PM
Lt_Dan87 Lt_Dan87 is offline
Mein Auto: 2008 535i
Gotta replace my brake pads
Should i do it at the dealership or wal mart lol
I always have negative experiences at the dealership, they are rude and liars, and they charge way too much. I know very little about cars besides how to drive them, so i cant change these by myself (if thats possible). I would like to avoid the dealership, those guys are assholes, is this a job that any old garage can do?
Old 10-02-2012, 05:16 PM
DustinA DustinA is offline
Mein Auto: bmw 528i
Find a good local indy! Not sure i'd goto Walmart tho
Sent from my DROID RAZR using Bimmer App
Old 10-02-2012, 05:40 PM
Damon54 Damon54 is offline
Mein Auto: 545
Do most users here believe in the mantra that new pads require new rotors?
Old 10-02-2012, 06:11 PM
Wreckless Wreckless is offline
Mein Auto: 528ix
Brakes are not difficult at all. Any Indy shop should be able to get them done. Even better would be to do it yourself. Check out YouTube and you'll see tons of videos about changing brakes.
Sent from my Galaxy Nexus using Bimmer App
Old 10-02-2012, 07:22 PM
dwlink's Avatar
dwlink dwlink is offline
Mein Auto: 435i Gran Coupe
The thread below is by far the most useful and detailed brake job DIY you will find. Its for a 6er, but the procedure is nearly identical on our 5s.
http://www.bimmerfest.com/forums/sho...d.php?t=523439
Give yourself a full afternoon if you are doing all 4 corners and make sure to not cheap out on any of the tools you are using.
2015 BMW 435i GC MSport (ED Sept 29, 2014)
2004 BMW 530i (retired)
Old 10-03-2012, 04:59 AM
Well i probably wont be doing it myself that is for sure. Do the BMW brake pads require "special" equipment or experts that the independent garages wont have? My dealership always makes it seem that way..
I just want to make sure its okay to take my car to an independent place for this brake pad job and not come out with faulty pads or something. I know it depends largely on the specific place i bring it too, but im positive i can get a good one
Old 10-03-2012, 05:10 AM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
Any independent shop can handle brake pads.
Honestly most people could do it with just basic tools, just that a lot would rather not have to deal with it
Old 10-03-2012, 05:56 AM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
I've done it a few times, Audi and BMW, the toughest thing is the 7mm caliper pin; no socket since the clearance is tight, I even tried grounding up a 7mm-socket drive still can't get the socket in there. So 7mm L-wrench it is, sometimes attatch to pry-bar if it won;t budge. the rest is easy just a bit dirty/dusty.
Old 10-03-2012, 07:07 AM
Jay Arras's Avatar
Jay Arras Jay Arras is offline
Casual Fanatic
Mein Auto: 2007 530xi 6 speed manual
Not always
I was told by my indy that front rotors will probably need replacing every other time you replace front pads because they do 75% of the work. But an inspection is usually the deciding factor.
Old 10-03-2012, 07:57 AM
Oceans10's Avatar
Oceans10 Oceans10 is offline
Mein Auto: BMW 535i + 535XI wagon
+1
The pads and rotors are designed to wear simultaneously. This is part of the grabby effect that makes them so great, there is so much feel to them. So usually you replace both together, but have a good independent mechanic look at the rotors first.
If they are substantially worn you wil run the risk of warping them with new pads. The fronts do 75-80% of the braking, so pay special attention to those.
Do not go to the dealership, they will charge 2-3 times as much for same job. Buy the parts yourself at Turner Motorsports, ECS Tuning, or any of these places online. Even Tire Rack is a good source. You can also call these places and discuss your needs, and the reps will give you good advice usually.
In my "unbiased" opinion stealerships try to maximize the opportunity and are completely shameless about it. Their prices are heavily marked up and they inflate every situation and try to scare customers with bogus explanations.
They have a right to run their busines in this manner, but I think they cater to suckers who volunteer to being taken to the cleaners. Tehere is nothig special about BMW brakes except the components which are made by sub suppliers. Only difference is the logo on the box they are shipped in. BMW pads are made by Textar and Jurid. Once you have the part number you can google it and find a good dealer and price.
Audio: Jehnert Flatline speakers, Mobridge M1000 DA2 prepro, Helix P-DSP, Zapco Z-150.6 amp, CIC iDrive upgrade
Performance: MHD Pro Tune, AR Downpipes, ER FMIC/CP, DCI, RB turbos and inlets, KW V2 coilovers, Fuel-It Stage 2 pump w Ported fuel rail, Mfactory LSD
Old 10-03-2012, 09:39 AM
I have spoken to AAMCO and the dealership, and the price difference is almost $1000, that is insane. The guy at AAMCO said the brake pads are "aftermarket." What exactly does that mean? I didnt want to sound like an idiot over the phone so i was just said okay thanks.
Old 10-03-2012, 09:41 AM
DIY'er
That they aren't manufactured by BMW
But neither are the ones that BMW sells you either (although they will probably come in a box with a BMW logo on them)
Old 10-03-2012, 09:43 AM
Alright yall i appreciate all the responses, this forum has always been helpful for my many (sometimes dumb) questions.
Old 10-03-2012, 10:40 AM
Oceans10's Avatar
http://www.turnermotorsport.com/p-29...l-package.aspx
Here's a good source. You can either buy the full kit with rotors and pads for front and rear, or go for pads if current rotors aren't too worn.
Labor shouldn't be too bad, maybe a 2 hour job total.
This is for a 535i as you list on your profile. Not an Xi which has a different kit.
Old 10-03-2012, 04:33 PM
Mein Auto: 545
Just looked over my order that I have yet to install.
Both my Front & Rear Rotors measured out of spec.
Ordered Fronts only so far. My maintenance preference is to order as high a quality parts as I want to pay for & then find an Indy that has no issue with the fact that he will be making his money on the labor.
Front Brakes E-60 545i
Pads of choice were Axxis Deluxe Advanced
Rotors: Centric Power Slot Premium High Carbon
125.34071
I have been using Brake Warehouse for a # years & have been happy.
2 install steps I will look for are to make sure that the brake pistons are opened only with the bleeder valves in the open position & I will opt to do a proper Pad Bed In procedure myself.
