Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M Series > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 10-03-2012, 11:26 AM
smoon1271 smoon1271 is offline
Mein Auto: E36 325i & M3
Convertible top reset and broken plate, help!
Hello Gentlemen, It's not been my day. I drove over the rough road last night and the LED on the convertible top switch started blinking. When I tried to reset the convertible top, it would not respond at all while LED still blinks. As instructed in many articles, I was hoping to manually open the top as turning the hex screw million times. Just before that, I discovered the "top lock" - I don't know exact name of it - was already cracked. When I unscrew the lock plate (see photos), it was completely shattered. I guessed I need some help from you.
Does anyone know what the part number for the part I broke? I tried to use gorilla glue but it would not stick well. I guess I need to buy new piece.
If the system would not initialize as LED still blinks, what should be the next step? It seems like either top control module or top motor may be bad.
Your help will be GREATLY appreciated.
Old 10-04-2012, 09:45 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Send a message via Skype™ to petriej
Look a the documents listed in this thread: https://www.bimmerfest.com/forums/sh...d.php?t=639047
And check realoem.com for the part. Will require some searching.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by batmobeamer View Post
So in other words **** you haha. Batmobeamer $
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011
convertible top, reset, top, vert
