Old 10-03-2012, 12:56 PM
woodhull woodhull is offline
Mein Auto: 2001 Z3
CE light/ stalls sometimes immediately after start
I have the CE light on all the time now, it was intermittent. Sometime the car stalls immediately after it starts other times it will be ok in neutral but as soon as I shift into gear it stalls. When I restart it will remain started if I keep it at around 1500 rpms for a minute and then it will be fine. Also sluggish.
Old 10-05-2012, 11:46 AM
Benjamin757 Benjamin757 is offline
Dr. E36
Mein Auto: 1998 BMW Z3 2.8
sounds like a classic sign of a worn hardened vanos seal (o-ring) the job is a pain in the @$$ but here is more info. http://www.beisansystems.com/
What would you attempt
if you knew you
could not
fail?
Old 10-05-2012, 12:03 PM
Mikey48 Mikey48 is offline
Mein Auto: BMW Z4 3.0
I would have the codes pulled and see what is causing the SEL and take it from their. Good luck.
Old 10-05-2012, 06:30 PM
crewdog843's Avatar
crewdog843 crewdog843 is offline
Mein Auto: '08 Z4 3.0si Roadie
There is a BMW mantra which goes somewhat like this: The CEL/SES light is always emissions related, which basically means MAF, cam position sensor, or O2 sensors. Codes should tell you which one. Based on the fact that it was intermittent, and then full on, I would put money on the Cam Position Sensor.
