Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners / Enthusiasts
Old 02-15-2013, 10:13 AM
elester12 elester12 is offline
Mein Auto: Pinto
vacuum controlled engine mount
I posted this on another diesel site and figured I'd share over here as well.
If anyone has issues with their vacuum controlled engine mounts please check your vacuum lines leading to both mounts. I was getting excessive vibrations and found the vacuum line leading to the left engine mount leaking. Replaced the line and all is good. Hope this helps someone down the road!!
The two mounts vac line are connected to a "T-connecter". I noticed a crack in that as well.
Old 02-15-2013, 10:17 AM
Mein Auto: Pinto
number 6 was cracked on mine.
Name:	engine mount.png
Old 02-15-2013, 01:21 PM
BMWTurboDzl BMWTurboDzl is offline
Mein Auto: 335D
What do these things do?
Sent from my MB525 using Bimmer App
Old 02-15-2013, 03:53 PM
Penguin Penguin is offline
Mein Auto: Z4 and X5 Diesel
They change stiffness to reduce engine vibration, depending upon conditions, something like this:
Engine Mount Control DDE 4.0
The controllable engine mounts are switched to "hard" or "soft" corresponding to operating conditions.
Function
The pressure converter connects the engine mounts to the vacuum supply by means of hoses. When activated by the DDE control unit, the pressure converter switches vacuum through to the engine mounts so that they switch to "soft".
The engine mounts are activated at:
  • Road speed < 60 km/h and
  • Engine speeds < a value which depends on the coolant temperature as follows:
    Below -40 °C: 1200 rpm
    From -40 °C to -10 °C: 1200 rpm to 1050 rpm
    Above -10 °C: 1050
Old 02-16-2013, 06:45 AM
Flyingman's Avatar
Flyingman Flyingman is offline
hang up and drive!
Mein Auto: 335d
Wow, first I've heard of these being used in our cars.
Is it unique for the Ds or also the gas engines?
Actually I see on line it has been used on many cars especially transaxle. Soft at idle and then stiffens when put to work. I like the concept. Wonder where they came up with that idea?
Old 02-16-2013, 07:43 AM
finnbmw's Avatar
finnbmw finnbmw is offline
Mein Auto: 2010 & 2012 X5 35d
Interesting. I wonder if the X5 has the same thing? I have to remember to ask my SA next time I'll bring it in for service.
Old 02-16-2013, 07:44 AM
Pasa-d Pasa-d is offline
Mein Auto: 335d
Shortly after I got my car I found the hose going to my left engine mount was being pinched by the undertray. It would surely have worn through if I hadn't have found this.
'11 335d M-sport/Le Mans/Oyster/Glacier/Titanium angel eyes
Lifetime avg fuel economy: @27,000 miles, 35 mph, 28.0 mpg
Pollution is bad, but carbon isn't pollution!
Old 02-16-2013, 08:05 AM
Mein Auto: Pinto
My x5 has it too. Most service advisors don't even know what the difference between dpf and def is.
See here. http://realoem.com/bmw/showparts.do?...31&hg=22&fg=05
Old 02-16-2013, 08:10 AM
finnbmw's Avatar
Thanks for the info! How did you know that the line was leaking?
