Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Classifieds > Cars - Private Party
Do you have a car for sale? Are you looking for a new BMW? Check here daily as well as searching on craigslist and eBay Motors
Old 10-03-2012, 02:04 PM
Tj Hunter Tj Hunter is offline
TT rocket
Mein Auto: E82 TT, E83 si
2001 BMW M5 Imola on Caramel Extended Leather
I bought this from the 2nd owner, it was an older gentleman that had it as a weekend/fun car. It has been VERY well maintained before I owned it, I have all records from brand new. I do all my own maintenance as I have been working on BMW's for over 10 years now. I also do detail work, so the exterior is in great shape, it is a 11 year old car so there are rock chips, but nothing out of the ordinary. I drove it one winter in MN, there is ZERO rust on the car.
Since I have owned it I added:
UUC V12 conversion clutch and Flywheel
UUC Black Transmission Mount with enforcers
AFE Intake (not included)
Shark Injector software
E60 short shifter
Alcantara Shift Boot (not included)
BC Coilovers
+maintenance items
Bad: The drivers side door strip has a dent in it, from when I took the trim off to detail (it dropped and I caught it at a wrong angle) and the rear drivers door lower window trim has dents in it, from me putting it back onto the door using a rubber mallet...it left mallet marks (stupid on my part!). Other then that the car is pretty much top shape, as I said, I really planned to keep this indefinitely, but figured I would test the waters to see if anyone would be interested.
$16000
Specs:
131139 miles (its my daily so it will go up) Imolarot on Caramel Extended Leather, M-audio, PDC, every option other then sun shades
Since I have owned it I have done the following:
bought 88987 miles, before purchase I had a UUC V12 conversion clutch and lightweight flywheel install with UUC Black transmission mounts
91356 thermostat and sensor (Due to low Ktemp)
93415 O2 sensor
95947 BF Goodrich gforce sport F & R
97238 Jc chip
97510 VW Mafs and AFE Intake (Pro Dry S filters)
99199 5w-40 castrol synth
99419 OEM Bosch CPS x4
99449 Hengst fuel filter
100729 Depo (Projector39's) FXR retrofit LED Angel Eye headlights from Umnitza
101000 Winter tire
102392 Valve cover gaskets and Bosch spark plugs
103632 Steering hoses and reservoir, oil canister repair
104725 Mobil 1 and Hengst filter
107977 BMW OE chain tensioner
108634 summer tires
109721 painted bumper and fender (due to clearcoat coming off, seems to be pretty common on the E39 bumpers and fenders)
112363 mobil 1 0w-40 and Hengst filter, Royal Purple Syncromax trans fluid, Royal Purple 75w-140 rear diff fluid
116625 Continental DWS 275 35 18 rears
117631 left rear tire nail repair
117936 upper and lower control arms leomforder and krayln and rear drivers door window regulator
118895 ZHP Shift knob, E60 Short Shifter, Alcantara shift boot (Have ebrake alcantara as well just need to install it)
119150 Mobil 1 0-40w w/ Hengst filter
Akebono EUR 681 (front) and EUR 683 (rear) brake pads
Flat black dual exhaust (muffler delete)
119783 Continental DWS 275 35 18 rears swapped rears to front "square" set-up done
124660 Mobil 1 0-40 and 15-50 blend (5-2 ratio) and BMW OEM filter
125140 BC Coilover with extenders
129432 FSU replaced (Behr)
129547 rear window seal replace BMW OE 9-1-2012
130975 Liqui Moly GT1 10w-60
Old 10-05-2012, 06:30 AM
TT rocket
No interest...someone want to fill me in? Hard economy?
Old 10-05-2012, 10:55 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Send a message via Skype™ to petriej
It's been up for 1 day.
It's a bit pricey for the mileage, but not out of the question.
You say you do detail work, but the car is visibly dirty. It's a great car and I'm sure someone would love it. Feelers like this may require more time to get a gauge of interest. Also try m5board.com
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by EnserioJose View Post
Sorry. I'd imagine Seattle is a-hella-nother country.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011
Old 10-05-2012, 11:51 AM
TT rocket
Probably should not have posted that question here, I have had it up for sale on M5board and bimmerforums for about a month or so, and I have only had one person with a little interest. The other pics were when someone asked for interior and "issues" pics, so I snapped them one day when I was at work. I do detail work but I don't wash my car daily, usually once a week is good.
It is priced that way because of all the work that has go into it, everything has been addressed that are major M5 wear items...so someone could find one with a little less miles or cheaper, but then you are going to have to put work into it, ie) $2-3K in replacing wear items.
I am just surprised I have not gotten more interest in the car, thanks for the response.
Old 10-05-2012, 12:00 PM
petriej's Avatar
I didn't mean to be harsh. Honestly if I was in the market for one, yours would be near the top of the list. You've kept good records while you have had it and the car looks like it is well kept. The miles are near the sweet spot and it isn't over priced.
Good luck! I'm sure someone out there would love to buy it.
GGC BMW CCA #443004
Join the BMW CCA!
Old 10-05-2012, 12:05 PM
TT rocket
Not harsh at all, I know its a little higher then some out there right now, so that makes sense. I have just seen people that list theirs on M5board and they are gone in days...so I am like why mine no SELLZ, lol! Thanks a ton for the reply, that was exactly what I was looking for!
Old 10-23-2012, 05:57 AM
TT rocket
I am up and down about selling the car...but it needs to go to a good home, I have TOO many other things on my plate!
BUMPSKI!
Old 10-24-2012, 04:06 PM
nv6425 nv6425 is offline
Mein Auto: 2006 650i
Pretty car, I'm surprised it hasn't sold yet.
Present:
2013 Imperial Blue///M5/Executive Package/20" Wheels/DCT/Sakhir Orange Interior
2012 Black Sapphire 740i/ M-Sport/Black Interior
Past:
2012 Mineral White///M3 Coupe/Competition Package/DCT/Fox Red Interior
2008 Titanium Silver 650i Coupe/Sports Package/Nav/Logic 7/HUD/Black Interior
2006 Stratus Gray 650i Coupe/Sports Package/Nav/Logic 7/Cream Interior
2004 Titanium Silver///M3 Coupe/SMG/19"s/Xenons/Premium Package/Black Interior
Old 10-26-2012, 01:42 PM
TT rocket
Thanks, me too!
Old 11-02-2012, 07:28 AM
TT rocket
Ttt
Old 11-03-2012, 09:44 PM
TT rocket
Price drop!
Old 11-13-2012, 06:00 AM
TT rocket
Bump OBO!
Old 11-15-2012, 07:51 AM
TT rocket
Final drop, I am going to take off the intake as well as the shift knob, shift surround, put the stock headlights back in, which will need to have the adjusters replaced, and anything else that was not standard on the car.
Old 11-21-2012, 08:44 AM
TT rocket
No one is looking for a great Imola on Caramel with all the maintenance items done??? I Maybe flexible on upgraded parts included with the sale.
Old 11-28-2012, 05:51 AM
TT rocket
New engine mounts and tie rods going to be installed next week. A 4 wheel alignment will be done once the tie rod ends are in AND Winter tires are mounted!!!
Old 11-29-2012, 01:38 PM
TT rocket
$16000 including all mods? Found a car, but I would like to sell this first.
Old 11-29-2012, 01:39 PM
petriej's Avatar
I wish I could! I'm sure someone will.
GGC BMW CCA #443004
Join the BMW CCA!
Old 12-01-2012, 03:49 PM
TemporarySanity's Avatar
TemporarySanity TemporarySanity is offline
Mein Auto: 2000, 1995 540iA, 07 525
I'm in the market for a 2003 e39 540 but your car has captured my attention! It's nearly the price range I'm considering too. I'd have to convince the wife how much I NEED it, not just want it, though. Plus, you are on the other side of the country from me which will add to the overall amount I'd have to spend. Either way, good luck with the sale. It's a beautiful car!
I discovered I scream the same way whether I'm about to be eaten by a great white shark or if a piece of seaweed touches my foot.
Old 12-13-2012, 06:27 AM
TT rocket
This would make a GREAT Christmas gift for someone!!!
Old 12-26-2012, 10:21 AM
TT rocket
Bump, it is put away for the winter, for the most part, currently has 1324xx miles on it.
Old 12-26-2012, 10:49 AM
1985mb's Avatar
1985mb 1985mb is offline
A pair of I6s
Mein Auto: E93 335i, E90 330i
+1. Constructively I would like to suggest taking some new pictures and moving the ones in the OP into an album that you can link to. I always respect honest sellers who are upfront with any flaws, but the place to show them is not in your headline.
GLWS.
How does a "Status-tician" live with himself while driving an entry-level grocery-getter?
2012 Mercedes-Benz E350
Prev: E90 330i, E93 335i, etc.
Old 01-01-2013, 07:33 PM
TT rocket
GLWS.
I will get them up in a few days, its been -1-10's this weekend, I didnt want to wake the sleeping beast. I will try to take some when it warms up in the next few days.
Interested if I include my extra set of Style 65's? I would like to move this car, reasonable offers accepted.
Old 01-02-2013, 06:21 AM
TT rocket
It seems that people think the price is a little high I wanted to explain my rational. EVERYTHING maintenance wise has been taken care of on this car, UUC V12 clutch ($3000), BC Coilovers ($1000), Headlights ($700), Short Shifter/shift surround and ZHP Knob ($250), Muffler delete ($300), Front suspension components ($500), Extra Set of Style 65's ($1000)...etc. The miles are almost all highway miles, picked it up in Oklahoma (700 miles), as I used to travel 200+ miles every weekend for a year (10000 miles there), then went to and from California (5000 miles), and normal travel driving etc... So to add that up I have spent $6000-6500 above and beyond the purchase price of the car. Someone will be getting a deal on this car, I know it is a $1000-$2000 more then some cars, but you WILL have to put at least several thousand into the car when you buy it, so have it done already and add the bits to personalize the car to your self, or buy something that will need all the maintenance done, it is 6 of one and 1/2 a dozen of the other at that point.
Old 01-04-2013, 07:08 AM
TT rocket
More Pics
Old 01-15-2013, 05:15 AM
TT rocket
Bump!
