Opening Puma Cases for Dirty Valves - Page 2 - Bimmerfest - BMW Forums
Old 10-06-2012, 08:01 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is online now
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Originally Posted by anE934fun View Post
Am I missing something?
Yes: You still need to keep the injectors clean.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47° 35' 30.13" E11° 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 10-06-2012, 08:13 AM
anE934fun anE934fun is offline
Mein Auto: 2010 335d
But all of the ads from gasoline distributors (Chevron for example) talk about their high detergent gas cleaning valves of fouling.
Injectors aren't subjected to blowback fumes like intake valves are. My understanding of the carbonized intake tract issue is that it is caused by blowback fumes.
I am not trying to be pedantic; just trying to understand what appears to be two separate issues. With non- D.I. engines, high detergent gasoline definitely stops intake valve fouling. But D.I. engines don't expose the intake valves to the detergent in the gas. Although some engines (Audi sems more susceptible than BMW, but that is just a gess on my part) seem more susceptible to carbonized intake tract than others. It gets curiouser and curiouser.
Old 10-06-2012, 08:14 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
although im not sure if the formation of deposits is the same on a high pressure piezo injector-- i have not heard of any clogged piezo injectors, between the pressure and the environment, i have a strong feeling that the detergent in the gas has a negligible effect on keeping the injectors clean. i could be wrong though, havent looked into it much.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 10-06-2012, 08:18 AM
Which comes back to my original question about the benefit of using high detergent gas in D.I. engines....
Old 10-06-2012, 08:26 AM
marketing? old habits dying hard?
shell's marketing is sneaky, they dont come out and say it cleans DI, its implied
Is Shell V-Power Premium Gasoline safe for all vehicles?
Shell V-Power is effective in all gasoline-powered engines found in conventional, modern and hybrid vehicles as well as motorcycles, snowmobiles, and leisure marine vehicles.
Tested in today’s advanced turbo-charged and direct injection engines, Shell V-Power helps resist thermal breakdown at high temperatures, actively protecting against gunk under tough engine conditions.
Old 10-06-2012, 08:36 AM
galahad05's Avatar
galahad05 galahad05 is offline
Better with Butter
Mein Auto: 335i sedan 6MT
Jumping into the Way Back Machine....back when carburetors were King, you definitely had carbon fouling in the combustion chambers proper (i.e. piston tops). With multi-port fuel injection that was reduced.
I don't know if DI completely eliminates dirty pistons.....
Don't resent growing old. Many are denied the privilege.
-- Irish Proverb
Old 10-06-2012, 08:37 AM
I totally 'hear' you. If you extend your example to Chevron gas, does the absence of the V-Power additive in Chevron gas mean that owners of turbo-charged D.I. engines that run Chevron gas are doomed to carbonized intake tracts? I doubt it. And to date, I haven't seen a gas distributor run a comparison test advert that compares their gas vs. a non-branded gas on intake carbonization in turbo-charged D.I. engines. I wonder why no comparo ads?
Old 10-06-2012, 08:38 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
If you mean PCV exhaust, definitely.
I want a cooled catch-can w/crankcase return.
Am I asking too much?
Old 10-06-2012, 08:40 AM
I suspect the carbon fouling in carbureted engines was due more to reduced fuel metering precision of the carburetor compared to fuel injection.
Old 10-06-2012, 08:43 AM
Attachment 344566
Maybe in the engine that powers the replacement to the F30 cars? Although by then, BMW may have moved on to fuel cell power.
Old 10-06-2012, 08:52 AM
Interim solution:
Elastic intake valve alloy enables piston slap vibratory shock, fracturing carbon structures to fines requiring an electron microscope to resolve, coke becomes fuel.
Wascally huns!
