Old 10-03-2012, 04:12 PM
Trapper Trapper is offline
I'd rather by driving
Mein Auto: 2003 Z4 2.5 Titanium Silv
Unhappy Wife just broke my radio
My wife just borrowed my car and came back 20 minutes latter saying the radio won't turn on. She said when she started the car AC DC was blasting away and she pushed the radio button to turn it off. Now I can't get it to turn back on. Any one have this problem or know what the problem is? The radio on/off knob was a little sloppy before. I can pull and push the knob in and out about 1/2 and inch.
I have the business stereo with CD player with the premium stereo system. (no water in the trunk).
Old 10-04-2012, 04:08 AM
Mikey48 Mikey48 is offline
Mein Auto: BMW Z4 3.0
Check your Amp fuse. Amp is mounted in the trunk where the battery compartment. Good luck.
Old 10-04-2012, 05:18 AM
GA Z4 GA Z4 is offline
Mein Auto: 2004 Z4
If you can move the knob about a half an inch in and out it sounds to me like it may have come loose and you aren't actuating the switch when you push it like you think you are. Pull the knob off the shaft and see what's going on behind it.
Old 10-04-2012, 05:58 AM
Thanks Mikey and Ga,
I don't think it is the amp as the radio does not turn on and display a radio station or a track from my ipod. I am planning on pulling the radio out tonight when I get home to take a look at it. Hopefully a simple repair with some glue, if not I will probably have to replace the radio.
And take my wifes key away from her...."No more BMW you you!!"
Old 10-04-2012, 06:54 AM
GeorgeT's Avatar
GeorgeT GeorgeT is offline
Mein Auto: '07 750i BMW; '03 Z4 BMW
Originally Posted by Trapper View Post
My wife just borrowed my car...
Well, you see that's your problem right there.
Old 10-04-2012, 05:37 PM
FinneganZ FinneganZ is offline
Known as Finnegan
Mein Auto: 07 Sapphire Black Z4Mc
Uh, yeah, but that reminds me on the recent Jack in the Box "Scrabble" commercial. Might have undesirable secondary effects....
In any case, good luck with the fix!
2007 Sapphire Black Z4M / LeatherZ Goodies / Turner Camber Kit / Clutch Stop / Ultimate Pedals / DIY Stubby / #1047
2012 Golf TDI (DD)
Old 10-05-2012, 06:22 AM
Fixed it.
When I opened up the back of the radio I could see that the knob is a replacment item although I can't see where is broke off or even how it is connected to the face plate in the first place. However since I know the knob works (on/off and volume control) I just used a few drops of Gorilla Glue and reattached it to the main board. I took a picture of it. The picture is a bit fuzzy but the small square green circuit board is the part that came loose.
I guess I should let my wife back in the house now...
Old 10-05-2012, 06:57 AM
Mein Auto: 2004 Z4
Gorilla Glue, you can't go wrong there! Thanks for the update, glad everything worked. Yes you should let your wife back in the house now.
Old 10-05-2012, 07:33 AM
STIHLBOLTS STIHLBOLTS is offline
Hat's On, Tops Down!
Mein Auto: 2013 335is
Question is will you let her touch the radio controls again?
2013 335is Convertible
MODS:M3 Strut Brace / Smart Top Module / Ikon Lip and spoiler
BMWCCA Member
Previous: 2004 3.0 Z / 2008 Z4M
Old 10-05-2012, 08:17 AM
I think she learned her lesson...it rained last night
Old 10-05-2012, 08:54 PM
tohbi tohbi is offline
Mein Auto: z3 '97 atlanta blue 2.8
gorilla glue is urethane isn't it, requiring clamping? what i like about epoxy is it doesn't require clamping although it doesn't attach well to slick plastic parts.
has anyone tried plastic welding? i've heard of it but not tried it.
Old 10-08-2012, 03:56 AM
Rhino Glue is the best. You can buy it on line. This is the best and fastest bonding glue I have ever used ! Good luck !
