Old 10-03-2012, 07:36 AM
murraye82 murraye82 is offline
Mein Auto: 99 M3
Exclamation guages not working please help!!!!!
hey everyone thanks for viewing the post i am clueless as to whats going on here
i have a 2000 323i i had my power steering rack replaced then i get the dreaded call "was your traction control light on?" so long story short i get my car back
traction control light is on
red brake light is on
tachometer is not working
engine temp gauge maxes out soon as i start the car
fuel gauge is working but fuel estimation does not work
ive verified the fuses are ok
i was thinking maybe the cluster but the speedo is working fine
the garage replaced the clock ring in the steering wheel thinking they screwed it up while doing the rack.
i would greatly appreciate any input or suggestions
Old 10-03-2012, 07:55 AM
Fast Bob's Avatar
Keeping it surreal
Any idea how old the battery is ?
The road goes ever onward....
(R.I.P. Jever)
*Please support the Wounded Warrior Project*
Mein Auto: 99 M3
i replaced the battery a week ago
Old 10-04-2012, 09:07 AM
GoForthFast GoForthFast is online now
Mein Auto: '04 330Ci 6-speed
Could be a defective battery or even alternator then.
Have you used the OBC to check the voltage? Or if that won't work, back to the old fashioned VOM?
I'm not dismissing that you just had the shop change out your rack. And if I could think of some connection, I'd surely pass that along.
But on the surface of it, I cannot think of anything close to the rack that would affect your cluster. Nonetheless, I'd probably want to get under there to see if any wires in the rack vicinity look disturbed.
And did they go in from the top and remove the MAF and boot perhaps? To get to the reservoir? Could have messed up a connector up there.
Old 10-04-2012, 09:46 AM
Fast Bob's Avatar
Keeping it surreal
Make sure the battery`s ground connection (to the body) is clean and tight.
(R.I.P. Jever)
Old 10-04-2012, 10:12 AM
Mein Auto: 99 M3
obc battery test was 14
i did the cluster test was ok as well all gauges did function
ground is clean and on there well
Old 10-04-2012, 08:14 PM
ikinkk ikinkk is offline
Mein Auto: 325i
I had the same problem today.. I changed the fuses for the cluster and it seemed to have fixed it. check them and see if they are blown. The three fives for my cluster were.
Step one: turn off DSC.
Old 10-04-2012, 10:44 PM
He already said the fuses are good. But it might be good to check them for good solid contact.
cluster, gauges not working, speed sensor
