E46 (1999 - 2006)
Old 10-03-2012, 06:24 PM
CPBIII CPBIII is offline
Mein Auto: 2002 325i
Problems after CVV/Oil Separator replacement
So that you won't have to ream me later, let me start by saying that I began this project with some bad advice from the service writer at the local BMW dealership. Mainly, that the intake has to come off to replace this valve. It DOESN'T. I know that now.
So while I was in the midst of taking the intake off, I also disconnected and completely removed the fuel injection rail.
I put everything back together, and have a dead miss on cylinder 4 from error codes (not to mention it will barely idle).
Getting codes
P1342 Misfire during start Cylinder 1
P1349 Misfire Cylinder 4 with Fuel Cutoff
P0204 Injector Circuit Open Cylinder 4
Does this look like something as simple as the injector connector not being secure? Those connectors are on a single long fixture. I would think they all have to be at least in place, but maybe I didn't get it all way engaged???
So now it will barely idle without shaking your fillings loose. The engine will rev up, but it really doesn't want to.
Any ideas??? Any help is GREATLY appreciated.
Chris
Old 10-03-2012, 07:51 PM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
Retrace your steps and make sure you put everything back in the right place and everything that needs to be plugged in, is plugged in. It might be a good idea to disconnect and reconnect everything again, just to be sure it's all together right.
Jeff R.
Old 10-03-2012, 08:17 PM
That's the plan right now.
I did take extra care to not hit or bump the ejectors while they were out. Would three days of exposure to dry air have any effect on them I wonder??
Old 10-04-2012, 09:26 AM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
Injectors would not be hurt by getting dry. They sit that way in stock for years and are OK.
Rough idle could be lack of a cylinder or two not firing. Yes, it could be a connector did not mate up with injector properly. I'd suspect that first.
In the future and for anyone else, don't take off the fuel rail is you don't have to. Just set it aside and work around it.
Old 10-04-2012, 09:34 AM
Fast Bob's Avatar
Fast Bob Fast Bob is online now
Keeping it surreal
You can also start the "Process Of Elimination" by swapping the number 3 and 4 coils, and see if the fault follows the coil. If that doesn`t reveal anything, try the same thing with the injectors.
Good luck !
The road goes ever onward....
(R.I.P. Jever)
Old 10-04-2012, 10:25 AM
j_schroeder's Avatar
j_schroeder j_schroeder is offline
Mein Auto: 330ci
I haven't had a bmw fuel injector off but if there are o rings replace them. A bad sealed injector can cause similar issues if its bad enough.
Sent from my DROID2 using Bimmer App
2001 330CI
Old 10-04-2012, 08:46 PM
chansta chansta is offline
Learning Daily
Mein Auto: 89 CIVIC
Getting codes
Chris
lets start with that.
iATN
Old 10-04-2012, 10:48 PM
Before I'd toy around with swapping injectors (no walk in the park), I'd listen to each one with a stethoscope for the clicking sound they make when working.
Worn O-ring could be responsible if they were not replaced when the fuel rail was reinstalled. Should not be reused.
Old 10-05-2012, 07:11 AM
I R&Red the long connector that has all the fuel injector terminals. That seems to have cured the misfire issue on cylinder 4. Still having problems though with lean codes:
http://www.bimmerfest.com/forums/sho...019&highlight=
