Old 10-04-2012, 02:01 AM
bigmind69 bigmind69 is offline
Mein Auto: BMW
540i 2001 Starting Engine Issue
I have bmw e39 540i 2001 ,Usually in the morning car start fine and runs fine. when it reach its normal temperature and turn off the car it do the below issue.
Here are my symptoms as follows the lower the fuel gets past half a tank the longer the crank. (If I do not shut the ignition off during a long crank it slowly catches like it is flooded then i turn it off and then on it will Start directly and runs normal.
I have already Replaced New Fuel Pump and Filter with Regulator Valve
Old 10-04-2012, 03:44 AM
veneficus veneficus is offline
Mein Auto: E39 (M62) 540i
Have you checked all the fuses?
