E30 (1982 - 1993)
Old 10-04-2012, 07:21 AM
Gasturbine Gasturbine is offline
Mein Auto: '87 325i Cabrio
Help please!
m trying to take the radio/HVAC panel out to replace the computer with an analog clock. On another forum, a poster said to remove the heat and fan knobs, then remove the lower panel. Problem is, there is no lower panel, and the sliders are all in the same piece. In other words, the entire panel is one piece. How do I go about removing this correctly? It is a 1987 325ic.
Note; I found the two screws on the underside, and it will pull out about a half inch from the bottom, but the sliders seem to be catching...which is obvious as Im sure there are cables and/or some kind of linkage connected to them.
Old 10-04-2012, 07:30 AM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 99' 540i M-Sport
http://www.unofficialbmw.com/repair_faqs/obc.html
Looks like you gotta pull the knobs off the hvac.. their should be some screws behind the plate. Screws also behind hazard button, and behind the dummy button. That should help a little.
1999 540i M-Sport
Silver/Black
Still fresh and Minty
1985 335i
Black on Black coupe 5spd
R.I.P
1979 Trans Am 10th Anniversary
#16 of 5,683 made
KOI Import Parts-- 513-771-7777
Old 10-05-2012, 12:32 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
You got it.
Its also possible to get in to the four screws holding the OBC in from the glovebox if you drop the plastic panel.
I suspect you will run into issues with wiring the clock up though as the analouge clock wiring will not be there.
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 10-05-2012, 01:30 AM
BmwMan92's Avatar
BmwMan92 BmwMan92 is offline
I <3 my E34
Mein Auto: 1985 318i// 1988 325e
Two small black phillips screws up and under the console. One behind your speaker fade switch and one behind your hazard switch.
Good luck getting that console back on the way it was. Takes alot of concentration.
Brandon
http://www.facebook.com/brandon.m.fore
Originally Posted by v8bimmer View Post
I just dont see any other logical way around this problem.
Old 10-05-2012, 03:44 AM
Terrains's Avatar
Terrains Terrains is offline
Mein Auto: 1987 BMW 325e
Yeah make sure when you put everything back, you're anal about it. Because I must have missed something somewhere, and the bottom of the panel is sticking out a bit. Don't have enough patience to do all of that again
Old 10-05-2012, 06:21 AM
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
those slider knobs pull right off, may take some force but thats how they come off...
Old 10-05-2012, 07:33 AM
markseven markseven is offline
an audience of One
Mein Auto: Go Kart with AC
Read through this. It has pics, too.
http://home.comcast.net/~cdeegan9/da...shboard_1.html
I Timothy 2:1-2
