Old 10-04-2012, 12:54 PM
Quest_908 Quest_908 is offline
Quest_908
Mein Auto: 01 530i and 04 aviator
angel eyes/halo
how do you get your DRL killed and set it up so your angel eyes/halos are the only light on? I see it on all kinds of BMWs but mine are only on if i have my headlights on or DRL on and i hat it, the angel eyes are one of my favorite features and id like to show them off. i have a 2001 530i with halogen lights
Old 10-04-2012, 01:16 PM
teklord69 teklord69 is offline
Mein Auto: 1993 BMW 318i
Take the bulbs out?
2003 E39 530iA Titanium Silver w/ Sport Package
Old 10-05-2012, 06:39 AM
tmvE39/E53/Z32 tmvE39/E53/Z32 is offline
Mein Auto: 01 525i, 01 X5, 91 Z32TT
^Yup, that's a way to kill it.
DRL can be turned off by coding the LCM module. AEs can't be used as DRL by coding, IIRC. You can turn off the cold-check feature and hard-wired your AEs to the ECU to have them on when the key is in positon I and II.
01 Anthracite 525i Sport, with 01 E53 3.0 and 91 Z32TT
Old 10-06-2012, 10:58 AM
Quest_908
If you take out the bulb you won't have low beams, right?
Old 10-06-2012, 05:27 PM
You won't have High Beam. DRL is High Beam on low power.
Old 10-06-2012, 09:18 PM
RichDeezy RichDeezy is offline
Mein Auto: 2001 BMW 530i E39
and this is by simply removing the HIGH BEAM bulb? to have just rings?
Old 10-06-2012, 09:45 PM
540 M-Sport's Avatar
Mein Auto: 01' 540 M-Sport cdn, F355
No. As previously stated, to turn off the DRLs you must have the car coded, either at the dealer, or an independant with the proper software. The ghetto way to go around this, is to pull the bulbs out of the high beams, which is what the DRLs work off, only at 50% power. Or just unplug them.
There is no way to code the LCM to operate the angel eyes as your DRLs. You could just turn your parking lights on.
Factory M-Sport with factory installed M-tech bumpers, factory Bluetooth, factory M-Audio 10" dual voice coil subs, homelink, M5 rear stabilizer bar, Bilstein B14 PSS coil overs, stop tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, strong strut front upper stress bar.
Old 10-06-2012, 09:52 PM
i see i see, thats what ive been doing but my halos are incredibly dim and blue-ish (due to my aftermarket POS's, that PO purchased) i wish when my regular lights were on you can see my halos around the high beam as i see on the newer BMW's but agh
