New owner- 2003 530i, suggestions please
Greetings,
I am a new owner of a good condition 2003 e39. I am looking for suggestions on what routine checks and maintenance I should do for it being at 93k miles. Seller says he serviced it with oil change done and put a new valve cover gasket. Car drives great and everything seems as good as he described it. I want to learn and do DIY maintenance on basic stuff. I have had good learning experience with my camry so hopefully that will help alongside all the good DIY threads here. I plan to go HID for the lights and would like to know what's the best option. Should I change all fluids at this time? If not which ones? What about water pump and timing belt? Wow...lots of questions and lot to learn. I hope to enjoy it all. Thanks, BM109R |
Congrats on the car. Post Pics.
At 93K, I would recommend a complete coling system overhaul around 100K. This is the weak link to the car (@ 100K+) and will restore original reliability. The cost is about $700 in parts + your 6-8 hrs of your labor. The DIYs are on this site.
The second thing I would recommend is to replace your Vanos seals. This is the single best value performance maintenance you can do. Go to the Beisan website for details on the problem and the fix. Search this site for testimonials. About $100 for parts plus 5-6 hrs of labor. And replace your O2 sensors at 100K. I got improved gas mileage and performance from that change. Lastly, if you really want to restore the original ride and handling, do a complete overhaul of the front suspension. That would be struts, tie rods, control arms, thrust arms and sway bar links. The cost is about $1200 in parts but will transform the car to near new ride and handling. |
Gee, thanks for the tips. Thats a lot to DIY and I've never undertaken such time consuming projects but I'm willing to learn and take it one at a time. I can't even tell that the ride quality needs improvement yet because it feels and rides great as it is. I'm sure I would tell the difference as you say with the suspension overhaul and other performance fixes.
Pics to follow.... |
Pics attached. Purchased from VIP Auto in Fredericksburg, VA.
Wow, cool Individual interior... stone green?
I wouldn't neglect the cooling system, it should be #1 on your list. |
The angel eye lamp can be changed to a LED unit and it will look much better, this is an easy and popular mod. Do a search and ponder your choices. |
Vanos.... Well I did mine around the 90K 2 years ago. The seals were definitely loose/worn. However unlike others, I never saw much if any improvement in performance nor fuel mileage. Perhaps in my case, they were sealing well enough. Front suspension.... The weakest suspension part are the thrust arms. The oil filled rubber bushing connecting the arm to the chassis lasts if your lucky to 60K. Mine were shot when I bought mine at 52K as a CPO 4.5 years old. I kept getting front wheel vibrations that would go away when the dealer balanced the tires, then it was back again 1K miles later. From this forum I looked for the tell-tale stains on the bottom of the thrust arm which were the result of the bushing leaking oil. Brought this up with the dealer who told me they were fine. At 60K after being ticked off with constant steering wheel vibration I replaced the bushings with Myle heavy duty bushings. I'm at 142K now with no issues. IF you do this, buy the arm with the HD bushing installed from 1 of the sponsors (can't remember which vendor) replacing the bushing in the arm was the worst job I've done in 30+ years of working on my own cars. The rest of my front suspension parts are still fine at 142K. Ball joints are tight and the control arm with the rubber bushing (that gets far less flex than the thrust arm bushing) is still fine. My front struts were replaced at 85K. They were very weak and I did not know this until I replaced them. Unless you have lots of $$$. You need to learn how to work on your car. I STILL love driving this car after owning it for more than 5 years. However I look at all the NEEDED dollars in maintenance I had to put into this and compare it to other vehicles I've owned and would be broke if a dealer or Indy did all the work. My latest problem is the dreaded seat twist. Both front seats have this issue due to the seat cables. Yet another problem to fix. Did I mention that I LOVE driving my 03 530 IA with sport suspension.
Ever wonder why 5 series electrical issues are common and complicated.. Spend time here and you will understand why. http://www.bmw-planet.com/diagrams/r...9new/index.htm
The vendor of the Lemforder arms with Meyle bushings is EACEuroparts! |
Thanks Gentlemen, I will be doing a search on the recommendations. I kinda started already and I just have to filter through when I have time for the beat thread on cooling system overhaul. A link ot two on the most thorough ones would be much appreciated.
So I will set priority list in this order: 1. Cooling system overhaul 2. Vanos seal replacement 3. Front suspension overhaul On oil and filter change which I will do this weekend or next, is 5w30 ok for this model? I have had great results with Valvoline Synthetic 5w30 on my camry. Only $26 for a 5quart just at Walmart. Also, which is the best online shop for oem parts? Thanks all! |
Interior is light gray/black leather.
What about fog lights, are those HID as well? |
Fog lights are also hologen just as the highs. Look at the color (yellows hallogen vs whites/blues = xeon) easiest way to find out. unless someone is using fake HID a hallogen bulb that is painted blue to fake the xeon gas effect
Sent from my SPH-M820-BST using Bimmer App |
Potential work to do on a new E39 at 100k
http://forums.bimmerforums.com/forum...3&postcount=12 http://forums.bimmerforums.com/forum...29&postcount=6 http://www.bimmerfest.com/forums/sho...5&postcount=14 |
Sounds like a proper priority list, I'm sure you'll notice some other things as well. There are a billion oil threads, read up OEM parts - ebmwparts.com is great, bmwmercedesparts.com, I'm sure others will chime in with their favorite. furiousmethod.com can be useful for finding the lowest price but usually the OEM parts stores have the lowest price. |
Thanks again everyone. Is it safe to change the low beam bulb to 6000k? I'm not sure if hid bulb temps work with corresponding ballasts or not.
you can change to 6000K with no problems. BTW, you lucked out on the grey/black interior!
Let me rephrase......you don't need to change your LO beam lamps since they are Xenon HID lamps which produce a nice white color probably around the 6000K mark. These lamps require a warm up period which is why they take about 5 or more seconds to reach full brightness.
The yellowish color you're seeing is coming from the HI beam Halogen H7 lamps which are "dimmed" to operate as a daytime running light, this produces a color temp of appx 3500K. When you turn on the LO beams your DRL's should go out and then they light up at max output when you activate the HI beams. These can be changed to a lamp with a blue coating to render a more whitish color (looks better with LED angel eyes) but you loose some brightness in the process. The angel eye lamp is also a Halogen and, unless already changed, looks yellowish too. It's simple to swap these for LED lamps and get a nice white color to match your LO beam HID's. Your fogs, if factory, should be Halogen also. |
whoops, turk to the rescue on bad reading comprehension
Welcome...!
Yes, I would replace all of the fluids. 1. Engine oil 2. Transmission oil 3. Differential fluid 4. Coolant 5. Power steering fluid I would also check out this thread: http://forums.bimmerforums.com/forum...d.php?t=895713 Thanks! Jason
I've never had the mod bug bite on a car before. I'm excited about this car and its calling for mods already
I have a suzuki m109r that has a list too.
Good read. Thanks |
#25
