Old 10-04-2012, 07:44 PM
gm559 gm559 is offline
Mein Auto: 1999 BMW 528i
Can I get some help?
Winter is getting closer so I let my car warm up in the morning. It seems like it wants to turn off the rpms drop under 1000. It's turned off twice and I have no clue why.
Also its a 99 528i and when I put the key in and turn on the electrical on the radio doesn't turn on, the steering wheel doesn't adjust, and the horn don't honk. This only happens sometimes. I also noticed that when they do work the airbag light comes on. The only way I can fix it is take the key out and put it back it multiple times till it works.
Old 10-05-2012, 06:36 AM
rdl rdl is online now
Mein Auto: 530i 2003
The first, best step is to have the codes/DTCs read with a BMW E39 aware diagnostic system able to read every module in the car. A generic OBD code reader will be inadequate. These read only the emissions and safety related DTCs mandated by law. Several of the symptoms you are experiencing are rooted in other modules.
The DTCs will identify the module(s) and fault(s) to start the root cause analysis, probably plural.
Regards
RDL
Old 10-05-2012, 09:47 AM
Fast Bob's Avatar
Fast Bob Fast Bob is online now
Keeping it surreal
Recent BMWs are *extremely* battery-dependent, and a weak or failing battery can cause all sorts of seemingly unrelated problems. Anything beyond 4 years old is usually considered to "be on thin ice", so be advised. A failing battery can also destroy your alternator, leading to more expensive repairs.
The road goes ever onward....
(R.I.P. Jever)
*Please support the Wounded Warrior Project*
Old 10-05-2012, 10:01 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
What he said.
[ONLY] If you're computer saavy, you can (even) download the software here:
- The most often recommended BMW diagnostic tools & cable interfaces (1)
What he said again. You have multiple problems.
Isolate them, one by one.
For example, does your driver seat NOT adjust electrically?
What he said too. Ask me how I know.
- One user's experience debugging a half-dead instrument cluster (1) which, after testing the fuses (1) battery & alternator (1) thankfully turned into an alternative battery search (1) and a simple battery replacement DIY (1)
My advice?
1. Fix the title of this thread and you'll get more help from us, today, and in the future. Everyone needs help. Please edit your first post to make the title more descriptive.
- Suggestions for forum subject titles (1)
2. Isolate the problems, one by one. First and foremost, charge the battery and then bring it to Autozone or O'Reillys for a free charging & starting system test.
3. Search the VERY best of E39 Links for each of your problems, e.g., /airbag F3, /alternator F3, /steering wheel F3, /ignition key F3, etc.
The oracle at Delphi couldn't tell you more than what is in those bestlinks already explaining the solution to all your problems above.
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders.
See also: E39 Bestlinks & How to easily find what you need, in seconds!
Old 10-05-2012, 11:55 AM
chiefwej's Avatar
chiefwej chiefwej is offline
Freude am Fahren
Mein Auto: 2003 540i/6 //m-tech
Your problems could be the ignition switch. Radio, seat and steering wheel power issues are often traced back to the ignition switch. Try moving the visor down and back, both with the visor light on and off to see if affects any of your problems. If so it's probably the ignition switch.
chiefwej 2003 540i ///m-tech 6-speed
Black Sapphire Metallic w/gray
Old 10-05-2012, 12:18 PM
BentValve's Avatar
BentValve BentValve is offline
Mein Auto: 00 528i 3 pedals
The first issue sounds like a vanos problem.
Old 10-05-2012, 12:52 PM
Nline6's Avatar
Nline6 Nline6 is offline
Always best in the NW
Mein Auto: E39 528it & E36 M3 sedan
My 528i, when cold and idling to warm up proir to driving in the morning seems to let the idle "dip" almost killing the engine. It has only died once but once the engine is at operating temp the "dip" tends to go away.
Touring the nation, one state at a time
Old 10-05-2012, 01:27 PM
BentValve's Avatar
A good way to check is to unplug the vanos solenoid prior to a cold start in the morning and start the car. If the issue does not happen, then it's your vanos seals.
Old 10-05-2012, 02:22 PM
Nline6's Avatar
Thank you, I was considering replaceing my Vanos seals anyways. I think I feel a slight sluggishness in the low RPMs but she moves just fine after 4k rpm. I will try to unplug it next time and see what happends.
Old 10-05-2012, 03:29 PM
EconoBox EconoBox is offline
Mein Auto: 2001 530i (E39) 120k
Your electrical issues are exactly described when the ignition switch fails.
DIY:
http://www.bimmerfest.com/forums/sho...d.php?t=356553
http://www.bimmerboard.com/forums/posts/244045
Old 10-05-2012, 05:23 PM
JasonSC540ia JasonSC540ia is offline
Mein Auto: 1999 740i
Tilt and horn not working....your ignition switch. No doubt.
