Old 10-04-2012, 07:46 PM
scottys scottys is offline
Mein Auto: 206 750LI
Hard braking, jerk at stop.
STANDARD DISCLAIMER: Yes, I did try searching. Nothing concrete. Please be nice.
PROBLEM: Just purchased a 2006 BMW 750LI. LOVE IT. Small issues here and there such as angel eye out (fixed it!!) but there is one that my mechanic and I disagree on. I am NOT a mechanic, but here is the issue:
Car drives perfect. Shifts perfect. Triptonic - perfect. Downshifts perfect. BUT, when I am coming to a stop I get a jerk. There is no unusual sound or unusual feeling in the wheel. The car simply doesn't want me to come to a smooth stop. If I am traveling at any speed and come to a stop with 'standard' brake pressure, the car will brake as usual. No shaking, no pulling. When you hit that last 5mph to 0mph stop, the stop will be accompanied by a jerk (at stop), then immediately let go - the car will move a little bit for a moment - and come to a complete stop. The jerk does not occur while the car is in motion, the jerk IS a premature stop. It is as if you are apply the brakes as usual, and right before you stop, you intentionally hit the brakes harder to have a sudden stop (the "jerk"). When the car does come to a stop, the car rocks back to forth a bit - more than you expect if you came to a hard stop. It almost seems like something is loose and is giving during braking.
If I purposely try to come to a smooth and gradual stop, I can minimize the jerk at the end, but can't get the really smooth stop that anyone would expect.
If I brake with harder pressure near the end, the car will still hit the premature stop but I can prevent the vehicle from the small movement forward.
I do not think this is a tranny issue as I even did this whole in Neutral and it still happened.
My mechanic originally thought that it was a common problem he see's that involves some parts in the front suspension (thrust bar's or something??). He has since told me that the rack needs to be replaced. I have a very hard time believing that. Again, I am not a mechanic, but in my old Mercedes S500 I had the rack replaced when I noticed I something was different in the wheel like the power steering was malfunctioning and I couldn't make fine adjustments. I could feel it. I can't feel anything in the wheel in my 750.
I have searched the forums and see this mentioned for other models, but not specifically with the E66. I have read it could be the tranny or some bushings. Before I go lay over $2000+ down on a new rack thought I would ask the community for some insight.
HELP. I would be more than happy to post a video to youtube from both the interior cabin experience and from the outside.
Thank you.
Old 10-04-2012, 07:55 PM
biigchiips biigchiips is offline
Mein Auto: '06 E66 & '95 E38
the factory BMW brakes are if you may 'sticky,' it exhibits good braking performance. I say deal with it or switch out for different brake pads, preferably ceramic brake pads since they are known to have better brake feel.
2006 Titanium Grey Metallic II 750Li
Old 10-04-2012, 07:57 PM
Carboy7's Avatar
Carboy7 Carboy7 is offline
Mein Auto: S550/750Li Individual/G37
I don't believe the brakes are THAT sticky that what you are describing is happening..unless I misunderstood your description.
It could also be that auto park is on (parking brake goes on a stops) or your transmission oil needs to be changed from downshifting from 2 to 1?
2008 BMW Individual E66 750Li
2013 Mercedes-Benz S550 4Matic
2013 Infiniti G37x
Old 10-05-2012, 05:02 AM
jcharris jcharris is offline
Mein Auto: 2002 745I
I think it's the transmission too because I have the same problem. My car sometimes will only downshift to 2nd, taking off from a stand still like an 1986 Ford Escort, lol....
2002 745I
Outrageous Daytona paint
Forgiato Rasoio
Drilled/Slotted aftermarket rotors
2006 Nissan Armada
Basic Silver
Gianna Wheels
JL Audio System/ Headrest monitors
Old 10-05-2012, 05:33 AM
DFEL750I's Avatar
DFEL750I DFEL750I is offline
Mein Auto: 750I
It's your guibo(flex disk) on the driveshaft.... Common problem. Part is about 130 and you should get the labour done for under 350 to install it. The guibo is a rubber flex disk that connects your driftsshaft to your transmission , the are metal rings within the rubber flex disk that wear off over time.
Old 10-05-2012, 07:03 AM
new760Liowner new760Liowner is offline
Mein Auto: E66 760, E38 750, E34 540
Put the car in manual mode and shift to 1st when near a stop and then apply the brake as usual to see if the jerk happens.
I've got a little hesitation in Drive when setting off that isn't present in Manual mode; may be a transmission software issue.
Old 10-02-2013, 02:50 PM
jayct jayct is offline
Mein Auto: bmw750i
its not the quibo or flex disc
I have the same problem. I changed the quibo it helped a little at first but the problem is still there.
I also did the software update and no luck with that too. If u figure the problem out please let me know what it is.
Old 10-02-2013, 02:56 PM
DFEL750I's Avatar
Mein Auto: 750I
I had the same issue. You come to a stop then after the stop car jerks forward a bit. Your problem is your torque converter.. It's is beginning to go. That also causes a rough idle and higher than normal fuel consumption. When I changed my torque converter all the issues went away. Problem is that it cost about $1000 to change the torque converter.
Old 10-02-2013, 03:38 PM
PAPER's Avatar
PAPER PAPER is offline
CRISP & CLEAN
Mein Auto: Ford Pinto
ouch ...
Old 10-02-2013, 04:05 PM
ssdriver27 ssdriver27 is offline
Mein Auto: 2003 745LI Alpine White
might also look at tension strut, mine did something similar and one day (I had mirrors in my garage for my weight lifting equipment) and noticed that when I stopped in the garage my front wheels would jerk forward after I stopped. my tension struts were shot and changed them and no more bump stopping. that may not be your problem but its much cheaper then the other mentioned problems. if that is it you can simply change the bushings out as they are simply pressed into the torque arm AKA tension strut.
2001 Camaro Z28 custom built and custom turbocharged 600+WHP @ 14PSI. (SOLD)
1996 Maxima GXE (commuter/camping/Dogs are coming with, car)
Old 10-02-2013, 05:31 PM
hairtrigger hairtrigger is offline
Mein Auto: 96 740IL
I had the same problem.....took to dealer and had the guibo replaced, after that never had it happen again.
Old 10-02-2013, 06:21 PM
bobbrum bobbrum is offline
Mein Auto: 2003 745Li
I replaced the Guibo joint and the Thrust Arms. I had two types of clunking noises when stopping.
Old 10-02-2013, 07:31 PM
DFEL750I's Avatar
Mein Auto: 750I
Originally Posted by PAPER View Post
ouch ...
Yeah it was painful but I was glad I resolved the issue.. It's a real pain. For those who think this is a guibo .., the way the problem is described it is not the case. With this issue the car comes to a complete stop then it lurches forward once... That happens when the torque converter slips.
For the people have this problem ..with the car in drive try to rev the engine to about 2000 RPM with your foot on the brake... If you can't then it's definitely your torque converter. The stall on our torque converter is 2500 RPM which means you should be able to rev the engine up to 2500 RPM before the torque converter starts trying to turn in input shaft of the transmission.
Also pay attention when putting the car into D or R... You will feel the car squat a bit in the back.. That's because the torque converter is bad and the car is trying to move when it shouldn't.
Old 10-02-2013, 08:24 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
As others have said it's the transmission being jerky from 3-2 and 2-1. The rack really shouldn't have much to do with the problem you are having.
I would recommend checking the Guibo Flex Disk, and as well swapping out the fluid in the trans with some new stuff. I can somewhat agree with the member that posted the torque converter, with the new trans and converter in my car it's been shifting great for the last 30K miles.
2013 TL Advance 3.5L
2006 BMW 760Li - Alpine White/Ebony-Ivory Two Tone
2010 Honda Accord EX - Basque Red/Ivory
lOE Fog Lightsl
2007 MDX Sport/Ent.- NGM/Taupe
lRB Slotted RotorslRoof RailslFront & Rear GarnishlAuto Mirrorl
2004 TL NAVI Auto - SSM/Quartz
lComptech SwaybarlHacked NavlTVNAV2GolUSA-SPEClDVD PlayerlSwitchblade KeylRB Slotted RotorslA-Spec Brakesl
Old 12-17-2014, 10:14 AM
mindanalyzer mindanalyzer is offline
Mein Auto: 2014 BMW X3 Xdrive28i
My X3 has only 4000 miles but I have felt the rocking motion when getting to a full stop from day 1. At the beginning it was very common to the point that i thought that it was 'normal specifications' for a 2nd gen X3 (I was played the 'normal specifications' card so many times with my late Acura RDX that I got used to that). Well, my X3 does not do it so often now but every now and then I would get the rocking motion when coming to a full stop. I did the test that you suggests and my results are
1- cold engine and trans: 2000 rpm
2- 5 min later; cold engine and trans: 1800 rpm
3- About 20 min later, engine and trans warmer: 2000 rpm
Could it be my Torque converter? This is a brand new 2014 x3 with 4k miles
It does not really bother me that much, unless this aggravates and requires a TC replacement
Old 12-17-2014, 10:34 AM
DFEL750I's Avatar
Mein Auto: 750I
when you did your tests are you saying that you cannot Rev the engine to 2000 RPM with the foot on the brake?
Old 12-17-2014, 10:52 AM
Yes, when firmly pressing the brake pedal, I gas the vehicle slowly and the revs dont go beyond 2000 rpm; They reach 1800-2000 and then come down;
PS: On a side note, I have not had that much rocking motion in a while, only sporadically. My mileage (mainly city driving) has never been great, 18.2 mpg is my average for the lifetime of the vehicle [mostly driven in comfort mode], although I have a lead foot
Old 12-17-2014, 01:45 PM
chamilun chamilun is offline
Mein Auto: 2008 535 ix
car did same before tranny error.
Change guibo, and change mech adapter and sleave.
I doubt very strongly its the torque converter
Old 01-17-2015, 04:09 AM
ztom's Avatar
ztom ztom is offline
I gotta have more cowbell
Mein Auto: 1997 528i
I may have this issue on one of my cars. The above seems close to a correct explanation & test. Although I think the torque converter always transfers some power and in this case is transferring too much torque near idle. I think the lurch is the tranny downshifts and so more leverage to move the car.
Old 01-17-2015, 04:47 AM
DFEL750I's Avatar
Mein Auto: 750I
Originally Posted by ztom View Post
I may have this issue on one of my cars. The above is a good explanation. Although I think the torque converter always transfers some power and normally tries to lock up only when rpm 2500?
The stall at 2500 rpm and lock up are two different things. Lock up can happen at different RPM and different speeds depending on gearing, whether youre accelerating etc.
When your foot is on the brake there should be little to zero power transfer from the torque converter below the stall RPM. Below 2500 the car should be able to Rev without you feeling it starting to squat with your foot on the brake. That's with a perfectly working torque converter. The problem is not many torque converters out there are 100% effecient. Listen to your car carefully when you change from neutral to D there should be no really noticeable change in RPM or engine sound. When I had fresh fluid and new torque converter I can change from N to D with no noticeable RPM change or engine sound difference. As fluid gets older and there is wear and tear, I can see a very small change in RPM when I first put the car into D.
