Old 10-04-2012, 09:43 PM
lovemyz3 lovemyz3 is offline
Mein Auto: Z3
While fixing Guibo/shift shaft seal what else should I replace?
Howdy,
My next project is to replace a leaky shift shaft seal and guibo.
What else should I fix while I am doing this and down there? I have 110K miles on the same clutch and I am thinking maybe do the clutch? Any ideas? How hard is the clutch?
Is the guibo the same as a universal joint?
Old 10-05-2012, 05:58 AM
JonM's Avatar
JonM JonM is offline
Moderator
Mein Auto: 01 Mc, 08 M3, Motorrad x2
This is the best DIY instructions for clutch replacement:
http://webspace.ringling.edu/~dplassma/cj/cj.html
It is not easy to get at the bolts on the top of the transmission. The rest of the job is a doable DIY however.
If you have the transmission out, you should replace the shift detent pins too:
http://webspace.ringling.edu/~dplass...hift_pins.html (also a great DIY from Vinci)
Jon Maddux
08 E90 M3 | 06 M Coupe | 01 M coupe | 99 M coupe
http://coupenut.blogspot.com/
http://x5nut.blogspot.com/
Old 10-05-2012, 07:20 AM
Randy Forbes's Avatar
Investigative Tinkerer
For the shift shaft seal, especially if you're doing it without removing the trans. there's a pretty easy fix. Instaed of risking damage to the shaft (scratches/gouges that will insure the new seal will leak) by trying to remove the old seal, push it in further; there's enough depth in the housing for two (2) seals to be stacked in there. Lubricate the rubber lip of the new seal before pressing it in, and now its only job is to catch what leaked past the original seal.
The shift pins are always a good idea, but I'd wait until the transmission was already being removed for a clutch job.
And yes, Derek's write-ups should answer any questions you have about the job(s); I could even volunteer his phone number for you...
Randy Forbes
2001///M Rdstr Steel Gray
Old 10-06-2012, 07:22 AM
Mein Auto: Z3
First off, I appreciate both of your responses.
So you think I should just put the new shift shaft seal behind the old one? I am not removing the transmission because I just planned to do guibo and seal unless I should do something else while there.
Is there a link to how to do Guibo and Shift Shaft Seal? Thank you.
So should I do the clutch while doing the guibo and seal? I don't want to move the transmission unless I have to.
Old 07-25-2013, 07:31 AM
Mein Auto: Z3
Any links on how to do giubo and shift shaft seal? Dealership wants $665 + tax
Old 07-25-2013, 07:47 AM
Blacklane Blacklane is online now
Mein Auto: 1998 Z3 Roadster
Most of the info you need is buried in this link (mentioned above):
Once you get the shift linkage disconnected, just lubricate the new shift shaft seal and tap it in using a deep socket, driving the old seal farther into the case.
Guibo installation instructions and torque specs are near the end of the link.
