Old 10-04-2012, 11:34 PM
BMW 328i Sedan BMW 328i Sedan is offline
Mein Auto: 2007 328i sedan
07 bmw 328i Sedan. NEED HELP!! CC ID CODES
So ever since i dodged a debris that has fallen off someones pick up I have been getting a yellow brake light, yellow triangle, along with some CC ID codes. All i did when i dodge the debris was jerk the steering wheel left and slammed on the brakes. The dash board indicators are the yellow triangle with a circle around it and my parking brake in yellow. When i restart the car the indicators would stay on until i drive for a few mins and it would go away, but only to come back when i make left or right turns. if i was to drive straight or make wide turns, nothing would pop up.
Things that pop up on the dash:
Yellow triangle
tire pressure
brake (looks like this (O) )
The codes are
CC ID 24- Dynamic Brake Control Assist Failed
CC ID 35- DSC Failed
CC ID 50- Run Flat Indicator Failed
CC ID 354- Start Assist Inactive
I thought it was because i needed to get my brakes changed. so i changed all 4 rotors, pads, and replaced the sensors as well. I also reset all of the brake sensors as well, but the indicators would still pop up again.
Any advise on what to do???
Old 10-07-2012, 05:33 PM
WookieMcg WookieMcg is offline
Mein Auto: 2007 BMW 328i E93
I have the same issue, I have yet to take it in to get fixed, as I believe it is just a screwy sensor. You probably just jarred the sensor in your steering wheel. At some point I will follow one of the below DIY's and fix it, as the dealership will charge approx 1100$.
This is a known issue:
http://www.bimmerfest.com/forums/sho...sc+malfunction
http://www.e90post.com/forums/showthread.php?t=520467
Safe travels
