Wrong oil in2006 325i having ticking in engine and c - Bimmerfest - BMW Forums
Old 10-25-2012, 06:55 PM
06silver325i 06silver325i is offline
Mein Auto: 2006 BMW 325i
I think i used the wrong oil wieght in my 2006 325i check engine light came on and now have a ticking noise in the engine and when idling the rpms drop and the car begins to shake. I used castrol edge full synthetic 5w30 is that ok for it?
Old 10-25-2012, 06:59 PM
ctuna ctuna is offline
Mein Auto: 325xi wagon
How much did you put in?
That really shouldn't cause a short term problem.
It takes 7 quarts, my Indy puts in 7.5
Old 10-25-2012, 07:01 PM
7 quarts
Old 10-25-2012, 08:24 PM
pointandgo's Avatar
The owner's manual says that if you install the wrong oil, remove it immediately.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 10-25-2012, 09:04 PM
aleks001 aleks001 is offline
Aleks
I highly doubt that oil is causing the issues you are experiencing.
Ticking noice: Probably the lifters, google/search it supper comman, solutions including changing all the lifters or engine block. Mine does it sometimes, I'm choosing to ignore it as it's very mild and not worth the cost of the fix.
RPM drop and shake: Check for codes. Most likely vanos solenoids or coil packs or spark plugs. BMW engines are picky with oil, but as any engine, it shouldn't really be too picky, especially if you are using the correct weight as you are.
I seriously doubt that any of the issues you are experiencing are caused by the oil you just changed.
Old 10-25-2012, 11:44 PM
BMW oil isn't any more expensive
BMW oil isn't any more expensive than any other top line synthetic so why not just use
that .
Tischer sells kits.
Are you sure you got the o rings in right in the filter.
Old 10-26-2012, 05:29 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Did you also change the filter? Was this a top-off or did you do an oil change? Have you checked the oil level since the problem started? Did you have ANY symptoms before the oil change?
The 5w30 Castrol Edge is not causing your problem.
