Hello all,
I am having problems with my car (1997 540i automatic) and was hoping to see if anyone might be able provide some guidance... Last week, I felt the car give a little jerk while driving on level ground at about 45-55 mph. It seemed to also affect the shifter a small bit (had my hand on it and I think it shook a little). I assumed I just hit something small in the road. Three days ago, while I was driving down the freeway at about 65 mph on level ground, it did it twice, about 5-10 min apart. At which point I realized I must not have hit something last week. Today, mid-day, I went to back out of a parking stall on level ground, the car shuttered and would not move when placed into reverse. Turned off the car, looked under the hood and under the car, did not see anything 'off'. Started the car and it worked/drove fine. Drove the car just a couple miles and parked again. Then, today, went to leave work, roughly 5 hours after the earlier issue. The car backed up fine and then as I went to exit the parking lot, car shuttered when I went to accelerate and would not move. Tried to put in reverse, shuttered and would not move. Turned the car on/off a few times, same result. Turned off for a couple minutes, then on and idled for a few minutes and car worked fine again and I was able to make it home. I bought the car used 7 months ago. The previous owner stated it had the tranny rebuilt about 20k miles before I bought it. I don't know who rebuilt it or exactly what they did. Another item to note, after I bought the car, and when it was raining hard (only when it rained hard), I heard and felt this loud banging coming from under the car, center area below the center console and back. My hubby did get it on a lift at school and found a loose connector and it seemed fine after that. If anyone has experience with this sort of issue and can offer some insight on the issues that I may potentially be plagued with and should look into, I would greatly appreciate it! Thank you! |
have you had the o2 sensors and spark plugs and fuel injectors checked... those may also be things to cause "jerks" or "bumps" and/or a rough ride i beleive... not sure, just a thought
We just replaced the spark plugs a few weeks ago. The O2 sensors are newer and checked out good last Saturday. Hubby checked the fuel injectors not long ago and those were fine too. Plus, when stopped, it 'runs' and revs, just shutters when I put it in gear (drive or reverse) and doesn't move when this problem happens.
When I was driving and it happened, it just seems like it is 'letting go', if that makes sense.
maybe a clutch issue , if its rebuilt or new tranny i doubt its actually the tranny. im no mechanic though either, but to me it sounds like it would be among the lines of an injector or sorts from what you describe. something just not "kicking" in correctly hmm... not sure, hope someone can have better input than I and help u figure it out...
Had the same issue my transmission needs to be replaced
Sent from my MB502 using Bimmer App |
How many miles on the car?
A scary 240k miles... but transmission was supposedly rebuilt around 210k miles.
Probably Trans
Have a dealer check your transmission fluid. There is no dipstick, so you cant do it. Had a similar problem and they changed the fluid and made sure it was full and it seemed to help.
Troll perhaps? A simple bump would have sufficed. Even better, would have been a two-second search of the bestlinks using /transmission F3 as your keyword: - ATF: Automatic transmission fluid (1) (2) (3) (4) & automatic transmission fluid & filter DIYs (1) (2) (3) (4) (5) & torque values (1) & how to find the hidden E39 transmission fluid level dipstick (1) & why ATF gushes out of the fill hole (1) & ZF 5HP19 facts (1)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 09-26-2012 at 08:22 PM. |
Wntrstr23,
We see this all the time where owners do get the transmission replaced/rebuilt by "Joe's Transmission repair shop" that "specializes" in European transmissions. Your car has a ZF transmission. There are only two sources of ZF factory authorized parts retailers here in CA. One source is obviously dealerships. Second is a source that I use for transmission replacements for jobs that I do on the side. Back to your issue. Sounds to me that you have a failure within your clutch B. It is a common issue when a transmission is repaired then refilled with incorrect fluid which causes premature failure within the drum/clutch pack. Second possibility would be a cracked drum which is similar to E46 no reverse. Basically what happens the fluid pressure drops within the clutch pack, thus not allowing engagement. Typical symptom would be once the transmission heats up, the crack and or drum expands which opens the crack= no reverse/no pressure. In short, you can change the fluid, have a transmission shop say "we'll adjust it" etc, but bottom line sounds like you'll need a transmission. If you're interested in a rebuilt transmission with a 2yr parts and labor warranty. Rebuilt by a ZF factory authorized re builder ( I will give you name of source that deals with me, and you can verify by ZF website) PM me. I'm located in the SF bay area and can perform the job for you. thanks for reading and good luck! |
Thanks for the replies!
The problem only occurred twice, both times were after the battery had been unhooked. The battery has not been unhooked for some time and the problem has not re-occurred since. It may have something to do with the transmission computer relearning according to two of the local BMW dealerships. |
| Tags |
| 1997, 540i, e39, transmission |
