Old 10-05-2012, 01:49 PM
utfootball4's Avatar
utfootball4 utfootball4 is offline
Mein Auto: 700 x etc
2004 bmw x3
I'm getting code P0174 - any idea what this code is?
Old 10-05-2012, 02:42 PM
x3brian x3brian is offline
Mein Auto: X3
I think that one means you are running lean...most likely has to do with a crack in the intake boot behind the MAF sensor, but could be something else with the intake. Odbii codes are universal and don't pinpoint specific failures. Also if it is the intake, after replacement you will have to clear the code...it won't go away automatically.
Any other symptoms, noises or other codes?
Old 10-05-2012, 06:03 PM
chrisk03 chrisk03 is offline
Mein Auto: 2011 335i M-Sport
Agree with x3brian, probably the intake boot. Well known issue on the X3...had same code last year on our 04 X3, replaced intake boot...fixed.
2011 335i M-Sport, BMW Performance Powerkit Version 1, 35% F1 Pinnacle Tint
Old 10-05-2012, 06:41 PM
Took it to my bmw guy - it read the same code along with bad gas cap. My guy told me to replace gas cap and see how things go...
Old 10-05-2012, 06:42 PM
What kind of noises should i be looking for?
Old 10-05-2012, 10:37 PM
Mein Auto: X3
Nothing in particular just curious if drivability has changed since MIL got activated.
Interesting. That code has more to do with intake than gas cap. I know my 09 has a separate dash light when the BMW gas cap code gets thrown. Keep us updated if problem comes back.
Old 10-06-2012, 04:05 AM
fivepointnine fivepointnine is offline
Mein Auto: BMW X3, Hyundai Genesis
I had that code and my intake book was cracked at the bellow part and my crank vent system was bad.
Old 10-06-2012, 08:06 AM
UncleJ UncleJ is offline
Mein Auto: '09 Cayenne "S"
My '06 also has a separate light for the gas cap.
Old 10-09-2012, 10:21 PM
Kevingovro Kevingovro is offline
Mein Auto: 2004 X3
Intake boot, Disa Valve, oil seperator and hoses... Could be a number of things
Old 10-10-2012, 06:33 AM
New gas cap and reset check engine light - all is well so far.
Old 10-10-2012, 06:35 AM
Let's hope the problem is solved....
Old 10-10-2012, 07:00 AM
legalfee's Avatar
legalfee legalfee is offline
Mein Auto: 2004 X3 2.5i 5AT
With mine it was MAF sensor. Cleared the code but it came back weeks later. I removed and cleaned the air filter and cleaned the MAF sensor with cleaner I got from Auto Zone.
http://www.linquist.net/motorsports/bmw/maf
Old 10-10-2012, 07:24 AM
Mein Auto: 2004 X3
Yeah the code will most likely come back in 60-100 miles
Old 10-10-2012, 11:11 PM
Been over 200miles - drive over 40miles to work each day....
Old 10-11-2012, 06:37 AM
How much did the repairs cost?
Old 10-11-2012, 08:56 AM
jdauria jdauria is offline
Mein Auto: E39 ///M5
You could probably change the intake boot yourself, but if not it should take <1hr of labor.
2000 ///M5 ///M Registry (09/99 Build)
Oxford Green Metallic II (430) | Caramel Nappa Leather (M3CR) | BMW Individual Black Birch |
Tuning Tech Tune by Frank Smith (http://www.tuningtechfs.com/)
Supersprint Headers
SuperSprint X-Pipe
Storm Motorwerks Products
2003 X5 4.6iS | Black Sapphire Metallic | Black Sport
2006 X3 3.0i M-Sport | Silver Grey | Terracotta | AT | Navigation | Premium Pkg | Cold Weather Pkg | AFE |
Old 10-11-2012, 11:51 AM
If it is the intake boot how long could I go before getting it fixed - 7-10days?
Old 10-11-2012, 11:53 AM
I am not handy - ill probably make it worst....
Old 10-12-2012, 11:20 AM
mlukas161's Avatar
mlukas161 mlukas161 is offline
Mein Auto: 03 330i, 04 X3
If its just a tear in the rubber intake boot you should have time. Your engine may run lean and waste some gas, but its not dangerous IMO.
Old 10-12-2012, 12:38 PM
Second this, I drove around in my e46 for a couple weeks before fixing my lower intake boot. But you have to be sure thats the problem You can literally stick your hand/fingers and feel if there is a hole.
Supersprint Headers
SuperSprint X-Pipe
Old 10-12-2012, 10:18 PM
intake boot is fairly easy to fix, you might bang up your knuckles trying to get that stupid plastic splash guard in and out. Biggest PITA is taking off the cabin filter housing
Old 10-13-2012, 06:47 AM
X3-terrestrial's Avatar
X3-terrestrial X3-terrestrial is offline
Aficionado
Mein Auto: '05 X3, '02 M3, '91 E30
If the code hasn't come back in more than 200 miles, I wouldn't worry about it. The intake boot probably is fine and it just needed a new gas cap. The gasket around it develop cracks and dries out letting pressure escape from the tank.
"If everything seems under control, you're just not going fast enough"
-Mario Andretti.
___________________
River City Bimmers BMW CCA
2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta.
2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
Old 10-13-2012, 09:25 AM
Mein Auto: X3
+1. Don't worry about it unless the code comes back. This is minor in the grand scheme and really only impact mpg/idle.
Old 10-16-2012, 05:08 AM
I spoke too soon - the light came back on last thur morning..... I notice when driving throughout my neighborhood when I step on the gas to accelerate I can hear a whistling noise for brief second...
**** It's a 2006 not 2004....
Old 10-16-2012, 05:25 AM
how many miles do you have on the x3? How is she running, sluggish? how is your MPG?
Supersprint Headers
SuperSprint X-Pipe
