Old 10-05-2012, 02:55 PM
bigmind69 bigmind69 is offline
Mein Auto: BMW
540i oil castrol 0w-30
does the castrol 0w-30 oil good for Hot climates ??? highest temp about 52 degree in summer
Old 10-05-2012, 03:58 PM
Jason5driver's Avatar
Jason5driver Jason5driver is offline
Mein Auto: E39 hamster w/ pin-wheel
52 degree Fahrenheit, or Celsius?
Old 10-05-2012, 04:37 PM
mbell666 mbell666 is offline
Mein Auto: e39 2002 540i6
I'd guess Celsius. I'd stick with recommended or heavier oil in hot climate, not thinner oil.
An e39 is like a beautiful wife, needs constant attention, lots of money, lets you down at the worse times but youd never be without it.
Old 10-05-2012, 04:45 PM
Mein Auto: BMW
Celsius
Old 10-05-2012, 05:47 PM
Celsius
52 degrees Celsius = 126.5 degrees Fahrenheit.
I would use this:
Mobil 1 - 15w-50:
http://www.mobiloil.com/USA-English/..._1_15W-50.aspx
Old 10-05-2012, 06:12 PM
JasonSC540ia JasonSC540ia is offline
Mein Auto: 1999 740i
Mobil 1 0W-40 Euopean Blend. Thats what BMW recommends if your not going to use there oil.
Old 10-05-2012, 09:42 PM
BigBoy740il's Avatar
BigBoy740il BigBoy740il is offline
Mein Auto: 1989/1991 E30; 2000 E38
The Mobil 1 0W40 is an approved replacement for the BMW LL 5W30, but in such a hot climate oil you need a heavier weight oil ( ie 10W30 or 10W40). In such a hot climate, you're more worried about the oil's ability to prevent thermal breakdown as opposed to cold temperature flow. Here in Arizona and last year in El Paso, Texas I ran 10W30 with no issues. In addition, some folks run the 10W40 and 15W40 to also reduce Vanos chatter.
Big Boyz with Bad Toyz
Big Boyz with Bad Toyz.
Old 10-05-2012, 10:00 PM
aioros aioros is offline
aioros
Mein Auto: 99 528i auto m-sport susp
As far as I know, the designated XXw means "winter", but what it really is the flow of the oil in a set temperature (cold temp usually). The "grade" or the 2nd number -20 to -50, is where the protection (everything included) comes from.
My suggestion is look for an oil with the ACEA spec A3/B4, BMW LL01, mb229.51
Sent from my MB860 using Bimmer App
Old 10-05-2012, 11:28 PM
chiefwej's Avatar
chiefwej chiefwej is offline
Freude am Fahren
Mein Auto: 2003 540i/6 //m-tech
The German made Castrol 0w30 (European Formula) is BMW LL 01 rated and is recommend by BMW for all temperatures and all climates. I have been using it for many years in my 540 here in Tucson where almost every single day in the summer is over 100 F.
chiefwej 2003 540i ///m-tech 6-speed
Black Sapphire Metallic w/gray
Old 10-06-2012, 03:15 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Originally Posted by mbell666 View Post
I'd guess Celsius
Why they use such a crazy system in Lebanon, I'll never figure out.
I mean, water is 'supposed' to boil at 212 degrees and to freeze at 32. That Centigrade system is just not natural!
Old 10-06-2012, 06:11 AM
aioros
Hahahahaha Bluebee you made me laughed. I hope you were being sarcastic. You know that most of the world uses the metric system to measure length/distance and the centigrade system to measure temperature.
Water boils at 100C and freezes at 0C
Everything is based on the number 10.
