Old 10-05-2012, 01:58 PM
Beth A Beth A is offline
Mein Auto: 2011 535I xdrive
fuel injector problems - 2011 5-series
I have a 2011 BMW 535i Xdrive. I bought the car new in May of 2011. For the past few months I've been having a problem with the fuel injector (I think). When I drive the car the first think in the morning, it sometimes lurches. Most of the time it's not that bad, but occassionally it is pretty severe. Took it to the dealer, and they couldn't find anything wrong. They want me to leave it overnight so they can drive it first thing in the morning. Only thing is that it doesn't have every time. Anyone else having these problems?
Old 10-07-2012, 07:59 PM
Rick24C Rick24C is offline
Mein Auto: 11 550i
Hi Beth,
I had my fuel injectors replaced on my '11 550 a month ago. Last week, I had to take my car back to the dealer because I was smelling gas and they replaced 2 injectors (again).
Symptoms: (does not happen all of the time)
Rough idling
Lost of power
Engine malfunction indicator (car goes into limp mode)
Hope this helps.
Old 10-08-2012, 07:56 AM
kc1953 kc1953 is offline
Mein Auto: 2012 535i.
Lurching sounds more like the famous "tip-in" problem. Have you had the global software update installed?
2012 535i, black sapphire metallic, oyster/black dakota, premium, premium sound, technology, sport, sport auto, heated front seats.
Old 10-08-2012, 04:26 PM
Mein Auto: 11 550i
Per my dealer, the Global software update are not for the 550i.
Old 10-08-2012, 08:02 PM
MBrown1003 MBrown1003 is offline
Mein Auto: 2014 F10 M5
Originally Posted by Rick24C View Post
Hi Beth,
Rough idling
Lost of power
Hope this helps.
I had a couple of instances of exactly what you describe. My dealer changed one spark plug, swapped a couple of ignition coils, and cleared the faults. It happened again a couple of weeks later, but that was five months ago.
Since then, the idle is a teeny, tiny bit lumpy (barely noticeable) and once in a while, starting it up takes a lot more cranking than usual.
And it's a 2011 550i, like yours. Any other '11 550i drivers having similar experiences?
2014 M5
Previously...
'11 F10 550i M Sport (ED Aug 1, 2011; US deliv, Sep 12, 2011)
'08 E90 M3
'07 E92 335i: ordered Nov '06; delivered Jan '07, totaled Sep '08.
'02 E39 M5: June 2002 - June 2007
'00 E39 540i/6, '97 E39 528i, '92 E34 525i + VW, MBz, Peugeot, Toyota, Olds
Old 10-08-2012, 09:32 PM
JT 550i SD's Avatar
JT 550i SD JT 550i SD is offline
Mein Auto: 2011 550i M Sport
had something similar....
my check engine/emissions light came on.
dealer originally changed a o2 sensor, but light came back on.
car was escalated to special tech team- they found 2 leaking injectors on left cylinder bank.
SA submitted PUMA case- ended up replacing all 8 injectors and spark plugs.
all good since then.
2011 550i : Alpine White l Black Dakota l Anthracite wood:M Sport pkg l Sport Trans l Active steering l Conven pkg l Driver asst pkg l Prem pkg 2 l 4 zone AC l Side/Top view cameras l HUD w/6wa ext blk pnl l BMW Media adptr /apps l M Decklid Spoiler l Clear Bra l V1 Radar; Ordered 4/9/11, Delivered 5/21/11
Retired BMW's;
-2008 550i MSport: deep Sea Blue/ Black, Loaded
-2005 545i : Silver Gray/ Auburn, Loaded
-1993 3215iA : Jet Black/ Black, Loaded[/FONT]
Old 05-31-2013, 12:54 PM
Jerris Jerris is offline
Mein Auto: 2010 535
Hello to all above,
I am also having fuel injector problems; for which the solution is to replace all of them. I'm wondering if any of you with fuel injector problems continued on your 5 series continued to experience problems after they were replaced? All feed back is helpful!
Jerris
Old 05-31-2013, 12:57 PM
Mein Auto: 2010 535
Hello to all above,
I've also experienced the similar "lurching problem" and a hesitation in the ignition upon a cold start. The solution is going to be to replace all the fuel injectors in my 5 series. So, I'm wondering if the problems persisted after the fuel injectors were replaced?
Jerris
Old 05-31-2013, 03:27 PM
Sonny184 Sonny184 is offline
Mein Auto: 2014 535i
I experienced the same problem with my new 535i, but the dealer told me that the fuel injection system operates at a very high pressure and you are always going to experience the rough startup until the pressure equalizes. Not sure this is your problem, but I have learned to deal with it.
Old 05-31-2013, 09:04 PM
Mein Auto: 11 550i
Jerris,
No, I have not experience any problems since my injectors were replaced.
Old 03-03-2014, 05:37 PM
shakumaku shakumaku is offline
Mein Auto: '01 525i
Had my brand new 2014 528iXdrive for 2 weeks. CEL came on @850miles. Took it to local dealer and SA knew it was injector change (while checking tire tread depth) before any diagnosis done.
Car/engine was running fine-no lurching hesitation at all. Dealer replacing injectors anyway.
