2000 740i No start after starter replacement - Bimmerfest - BMW Forums
Old 11-21-2012, 06:46 AM
sinbad1422 sinbad1422 is offline
Mein Auto: 2000 740i
Had the starter replaced, now the car won't start. Mechanic found cables from the positive terminal on the battery had melted together and repaired. Car will not start now, turns over but fuel pump is not turning on. New Crank shaft positon sensor, new cam position sensors, new battery, new fuel pump, Power at the relay, but no 2 sec prime when key is turned. No check engine light on. Help!!
Old 11-22-2012, 07:58 AM
First740i First740i is offline
Mein Auto: 740i
Maybe a short before the pump. I had a similar problem. My was the pump but I followed the wires and found some of the coating was rubbing off over time. (Poly from vibration) so check that out also.
Sent from my DROID4 using Bimmer App
HTML code is Off
