E36 (1991 - 1999)
Old 10-05-2012, 04:57 PM
bimmer claus's Avatar
bimmer claus bimmer claus is offline
Santa
Mein Auto: 95 M3
323is Tranny.
No issues with the tranny dont worry. Just had a few questions on the e36 autotragics theres - P N D 3 2 1- it also has that - a to m- button was just wondering when i throw it in 3rd it drives the same as Drive but it boosts the revlimit and pushes to redline what seems like with more umph (for lack of better terminology) was just wondering if anyone knew much about the operation behind the 3 2 1 gearing
95 Avus M3- Now with Supercharger.
Old 10-05-2012, 08:24 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
afaik, the m button holds the gear that you are in.
it doesn't make it a manual, and is a good way to destroy the transmission. most people do not use this button. the ones who do usually don't do it for long...
if you want a manual, get one.
the difference in the 3rd gear operation is telling the transmission computer to go into a sportier mode. it changes shift points making the car feel livelier.
overdrive does not engage like this, even if you bounce off rev limit, from what i have gathered.
there are owner manuals available online, and it covers the proper operation ofthis button and when it is designed to be used.
starting off on slick roads seems to stick in my mind, sort of like a 2nd gear start in a manual, to reduce wheel spin. simply putting the gear selector in '2' will not make it start off in this gear unless the 'm' button is also selected.
hope this helps. again, i have not read my owners manual for this as i do not own an automatic, so we;ll see what the others have to say.
df
Old 10-05-2012, 08:34 PM
Santa
Mein Auto: 95 M3
yeah was just amazed that theyd put a sporty mode in one of these esp on an auto was wondering if itll do any damage or what the story is and yes destroying the tranny is quite easy using the m button only time i use it is in drive on slippery roads it starts the car in a higher gear to reduce wheel spin was just curious if the 3 2 1 were indeed sport modes
Old 10-05-2012, 09:34 PM
from what i have read, putting the transmission in 3 lets the car run in a sportier mode, while the lower gears, 1 & 2, simply will run in the respective parameters (not sportier).
df
Old 10-06-2012, 12:34 AM
hornhospital's Avatar
D'oh, You Kids!
df
Correct. Putting it in 3 moves the 1-2 and 2-3 shift points up several hundred RPM, and stops upshifting at 3rd.
Quotes to live by:
Old 10-08-2012, 07:42 AM
Santa
Mein Auto: 95 M3
so it wont go into 4th this way then?
Old 10-08-2012, 09:12 AM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
Correct. You are locking it out of overdrive (4th).
Patrick ///04 330i ZHP///BMWCCA#465139
99 540i TiAg
98 328i hellrot (sold)
96 318iC black (sold)
Old 10-08-2012, 09:26 AM
Santa
Mein Auto: 95 M3
i mean is this truly bad for the tranny if i do it every once ina while for some fun its just fun (about the only fun you can get out of an auto) so was just curious about that is all thanks guys for all the responses very enlightening
Old 10-08-2012, 11:25 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Not bad for the transmission. Just don't go cruising in 3 on the highways, as it is unnecessary.
GGC BMW CCA #443004
Join the BMW CCA!
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 10-09-2012, 07:29 AM
Santa
Mein Auto: 95 M3
Thanks haha we just do a little auto xing so just thought this was sorta cool for the higher rev points is all thanks for all the great input fellas!
Old 10-09-2012, 07:39 AM
miles_trail's Avatar
miles_trail miles_trail is offline
I like pie.
Mein Auto: 96 318ti, 93 BMW 325IS
I say keep using it daily until the tranny blows and then buy my 5 speed swap kit
Sent from my ADR6300 using Bimmer App
Originally Posted by E36 Phantom View Post
How do you outcrazy a dude that lifts his engines without a hoist?
Old 10-09-2012, 07:57 AM
Santa
Mein Auto: 95 M3
lol hahah tell me some about this swap kit I thought they were fairly useless because you can never get the car to run like a factory manual due to computer issues (so ive read)
Old 10-09-2012, 09:16 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
These cars are fairly low-tech. Swapping in a manual trans is pretty easy, and there are no issues with computers like you mentioned.
1998 BMW 328is
1966 Pontiac GTO
Old 10-09-2012, 09:18 AM
Santa
Mein Auto: 95 M3
Even still it'd probably cost the better side of 3k when all is said and done unless of course you can find a totaled and tear her apart ima have to put some thought into this one guys thanks
Old 10-09-2012, 09:29 AM
ZeGerman's Avatar
Warm Leatherette
If you do the work yourself it will cost you nowhere near $3k. Probably not even half of that if you're savvy.
1998 BMW 328is
1966 Pontiac GTO
Old 10-09-2012, 09:35 AM
Santa
Mein Auto: 95 M3
hmmmm i mean if i did all that work id just wanna try and find a tranny without absurd mileage on it have to see what the local junkyards and craigslist has to offer very interested in this now to be honest already did the motor swap so a tranny will probably be needed soon ( even though this auto has 156k on it and runs like new) regardless still an auto. Thanks Ze ill see what i can find
Old 10-09-2012, 10:28 AM
I like pie.
I've got the trans, pedals, hydraulics, and drive shaft. You'd probably want to source a diff because mine is open slip and for a 318 (too high of a ratio for DDing a 6cyl) and you'd need all the bits that wear out like a clutch kit, giubo and trans mounts.
Old 10-09-2012, 10:31 AM
Santa
Mein Auto: 95 M3
Got brand new mounts driveshaft guibo and all that crap last week and gawd i want a lsd how hard are they to come by though only being in m3's :/
Old 10-09-2012, 10:54 AM
petriej's Avatar
THANK you...
GGC BMW CCA #443004
Join the BMW CCA!
Old 10-09-2012, 11:46 AM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
Not this again...
-CJ
Old 10-09-2012, 09:14 PM
D'oh, You Kids!
I guess my '93 325is is an M3 then? j/k Came stock with a 3.18 LSD. (it was part of the cold weather package, along with heated seats)
Originally Posted by cj.surr View Post
Not this again...
Quotes to live by:
Old 10-09-2012, 09:31 PM
cj.surr's Avatar
some kid
You gots da super rare 3.18:1 diff??
-CJ
Old 10-10-2012, 12:53 AM
D'oh, You Kids!
Oops. Good catch. 3.15:1
Quotes to live by:
Old 10-10-2012, 06:44 AM
Santa
Mein Auto: 95 M3
bahahahahah you mean GUIBO?!?!?!!? JOKING oooo so how hard is it to find me one of those diffs cold weather packages and m3's?
Old 10-10-2012, 08:54 AM
I like pie.
I'm talking to a guy in PA with 3 M3s he's parting, unfortunately they're all auto so they're 3.38:1 but that would mean really good acceleration.
