Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X1 E84 (2011 - current)
The new to the US BMW X1 will arrive at BMW dealers in the fall of 2012 as a 2013 model year. Get your X1 28i with either sDrive (RWD) or xDrive (AWD) or get the US exclusive I6 N55 powered X1 35i dDrive.
Old 10-07-2012, 06:08 PM
newc6 newc6 is offline
Mein Auto: 2013 Porsche Boxster S
oil specs and other stuff?
For those with a new X1 with the 4 cylinder, what oil is called for? What gas, premium? Do all BMW's no longer have oil dipsticks or does the N20 have one? Rear fluid, GF5? And anything else along those lines you might find helpful, I would really appreciate the info.
Old 10-08-2012, 05:44 AM
HotRodW HotRodW is offline
Mein Auto: 2013 X1, 2012 Q5
Approved oils: BMW (Castrol synthetic) High Performance 5W-30, BMW Longlife-01, or BMW Longlife-01FE. The manual doesn't provide detailed specs, and indicates "further information can be obtained from the service center". It does specify that up to one quart of API SM or higher quality oil can be used if level is low.
The recommended gasoline octane rating is 91. The minimum octane rating is 89. BP or other top tier brands recommended.
Rod
2013 X1 xDrive28i M Sport
2012 Q5 2.0T
2002 RSX
Old 10-08-2012, 08:48 AM
raleedy's Avatar
raleedy raleedy is offline
I paid for this airplane!
Mein Auto: 2008 E92 328i
http://e84.xbimmers.com/forums/showthread.php?t=734101
Old 10-08-2012, 06:24 PM
raleedy-Thanks, great info.
Couldn't ask for anything more. Thank you VERY much.
Old 10-08-2012, 11:08 PM
stary stary is offline
Mein Auto: pending...
also why are you worried about the oil? free service for the first 4yrs!
2013 X1 sDrive 28i, M-Sport package, Mineral Grey
Old 10-09-2012, 11:55 AM
Because I might be the kind of person who may want to change the oil between the free BMW service interval. If so, I need to use the correct spec oil. And I may want to change the diff fluid, or the brake fluid. I have a favorite brand I have used for 30 years and their stuff works great, usually at a lesser price than what BMW would charge, if it weren't free.
Old 10-15-2012, 09:16 PM
Gonepostal Gonepostal is offline
Mein Auto: 2010 Infiniti ex35 journe
The sales lady at one dealer I was at swore up and down,that these cars can run on 87:-/, funny how clueless they can be....
Old 10-16-2012, 08:13 AM
x3brian x3brian is offline
Mein Auto: X3
Newc6--I follow your same logic and change my oil every 7,500. I do always use the BMW 5w30 synthetic as it is reasonably priced at $6 a quart and it really is the best choice for how the engine is designed.
Also, no more dipstick on BMW engines. This started with the introduction of the n52 inline 6 motor when the e90 was released.
Let me count the ways.....but first and foremost yes you should worry. I have 99k on my 09 x3 with the 100k mile maintenance plan. Do you know how many free oil changes I got? 5. Yikes!!! That's approx 19k miles between changes. No matter how good your oil is it isn't going to last that long.
As a side note there is a well know valve ticking problem that develops in these motors around 50k to 60k (n52)....I strongly believe this in part caused by too long duration between changes. Also my n52 is quite as a church mouse.
Here is a nice article that shows the head off of two inline 6 m54 motors...one changed every 7k miles the other as BMW suggests:
http://www.bavarianmachine.com/doc_see_the_light.html
She was right. You can run 87 all day long with no ill impact to mpg, motor or fuel system. Performance differences are minor.
I am a super commuter and years ago I had a brand new 08 128 vert. I decided for 4 weeks I would run premium 91 and 4 weeks regular 87 all from chevron. It was spring so weather was a consistent temp in morning and night (California), driving conditions the same (80 miles each way at 80mph, 20 each way in stop and go) and I checked cold tire pressure every day.
Result -- there was less than a .3 mpg variance between 91 and 87 and no perceptible performance difference in normal driving.
Conclusion -- I have used 87 in all BMWs I have owned since. Like I said my 09 x3 has 99k miles on it no issues with mpg or fuel system so far...
Old 10-16-2012, 09:58 PM
Nice to meet a kindred spirit. Though I may only have 44 posts on this forum, I have been around cars for a while. And I also have other forums I post on. 7500 miles sounds about right and I also agree with you on the 87 octane. My biggest questions were pretty much answered by others but it's always nice to have backup. Thank you.
