NEED HELP .... How can i fix ?? Its leaking coolant... - Bimmerfest - BMW Forums
Old 10-05-2012, 05:30 PM
Beamer714530xi Beamer714530xi is offline
Mein Auto: 2006 BMW 530Xi
Exclamation NEED HELP .... How can i fix ?? Its leaking coolant...
Not sure whats going on it started leaking coolant ... Want to know what to do or how to replace ......
Old 10-06-2012, 05:32 AM
pcy pcy is offline
Mein Auto: '06 530i, '07 C280, ML320
That's the coolant temp sensor. O-ring on that temp sensor fails, leading to leak. O-ring can be purchased at the BMW dealer for couple of dollars. You can also buy a new temp sensor. New sensor comes with new o-ring.
Old 10-06-2012, 04:19 PM
Alright thanx.... Is it easy to replace???
I got woried because it was a small leak now its alot
Old 10-07-2012, 03:08 PM
pcy pcy is offline
Very easy to replace the o-ring on the temp sensor. Pull the metal clip on the temp sensor and pull the sensor straight up; remove the electrical connector on the sensor; remove the o-ring and replace it with new one.
Here are the pictures - the temp sensor goes in to that hole in the hose.
ID:	344710   Click image for larger version
Old 10-10-2012, 02:44 PM
Thnks really appreciated it
