Rear wheel bearings!$@&$) - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 09-26-2012, 10:03 PM
orangudane orangudane is offline
Mein Auto: 1989 325i sedan
Rear driver side wheel bearing went bad so I decided to replace both sides. Passenger side came out no problem and went in the same. The drivers side on the other hand is a not playing so nice. I pulled the center out of it while trying to pull it out, so now I have the outer casing stuck in there. Other then cutting it out you guys have any tips?
Old 09-27-2012, 12:09 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
dry ice in there, you can also buy it in a can as a spray.
E30 above Sold
Last updated 2nd January 2014
Old 09-27-2012, 07:39 AM
Brilliant, I tried using a torch on the outside but with no success
Old 10-05-2012, 09:28 PM
BMWFatherFigure's Avatar
Old School
Cut it with a Dremmel.
Current:
E38 Parts Car
Previous:
Old 10-06-2012, 04:45 AM
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
I use butane, it acts like liquid nitrogen just not as extreme and can shrink those races a good bit, enough to tap them out easily.
Takes a full can though and helps to do it on a day over 80*.
Old 10-06-2012, 06:27 PM
Old School
To get mine out I used a hand operated hydraulic gear puller (pusher). Worked very well. Maybe you could hire one? Brand i have is 'Sykes Picavant'
Current:
E38 Parts Car
Previous:
