Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 01-11-2012, 11:50 AM
rafarin003 rafarin003 is online now
Mein Auto: BMW 740IL/BMW X5
After market wheels BMW 740IL
Howdy,
I'm quite new here, I have been a BMW owner for 7 years now; my first one was a 525i 1995 then I bought a 740 Il 1999 5 years ago. Last year I bought a 2007 X5, I currently own both. Last year I decided to upgrade the 740 by purchasing a new set of flashy wheels to replace the factory ones;however, I kept getting terrible vibrations while driving mostly when I'm doing 45 mph. Despite the fact that I loved the wheels I had to remove them and go back to the original factory ones. I recently saw a set of 18" after market rims on EBAY which I like very much. Has anyone ever experienced such vibrations with the steering wheel after putting some after market wheels?
Any pointers will be greatly appreciated before I make a final decision about those awesome wheels.
Sent from my MOTWX435KT using Bimmer
Old 10-05-2012, 07:40 PM
BigBoy740il BigBoy740il is offline
Mein Auto: 1991 E30; 2000 E38
First off, your problem can be caused by a multitude of things. Bent rims, bad tires, worn suspension parts or non-hub centric rims. Step one, get your wheels high speed balanced. This checks the tires and rims. Next check to see if your rims have hub centric rings. These are metal or plastic inserts which reduce the rims inner bore to tightly fit the BMW's 72.1mm hub. Without them, your rims might mount off center and cause vibration. Finally, check your front suspension parts for looseness. Check the lower control arms, thrust arms, tie rod ends, and steering link for looseness. Repair anything problems found and have the car aligned.
Big Boyz with Bad Toyz
Big Boyz with Bad Toyz.
Old 10-05-2012, 09:28 PM
Smile
Thx for your input, I have already resolved that issue. You're absolutely right,the root cause of the vibration was the fact that I didn't have any hub rings. After installing one set of rings everything become smooth and steady.
Old 10-10-2012, 08:13 PM
BimmerBro BimmerBro is offline
Mr_Bimmer
Send a message via AIM to BimmerBro Send a message via Yahoo to BimmerBro
Mein Auto: 2001 Bmw 740i
Interesting..I have a set of aftermarket wheels and i have experienced the vibrations. I have all the wheels trued and checked for balance, but I don't recall anyone mentioning anything about these hub centric rings. I've actually taken the wheels off and put my factory wheels back and the vibration is gone. Where do you get these plastic or metal rings?
thanks
Photobucket
Old 10-11-2012, 10:52 AM
The hub rings are very cheap you can get the set for as low as $50 on ebay. Yes they will stop the vibration.
Old 10-14-2012, 07:07 PM
Mr_Bimmer
Thanks. Anyone have a pic of what these rings look like? Just want to make sure I'm getting the right thing.
Photobucket
Old 10-14-2012, 09:01 PM
Sobek Sobek is offline
Mein Auto: 1996 BMW 730iL
If you're using aftermarket wheels with a 74.1mm bore size (the most common really) then these are the hub centric rings you want;
http://www.ebay.com.au/itm/261036601276
Don't go plastic or cheapskate 'High school metal shop' aluminium from some yum cha brand... Get the good stuff, ie; the link above. They'll last forever and they have a conical shaped top lip that will fit almost all BMW rims beautifully. I've got another set on their way to me right now for some Style 95's I'm putting on.
HTML code is Off
