E34 (1989 - 1995)
1993 525i won't ccrank
just changed starter. no clicking or dimming of lights now. no anything when turning key. Aaaaaargh.
What happened before that? Why did you change the starter ? You probably messed something up during installation (happens all the time). Which means that its fixable. Go through exactly what you did in your mind. Its best to stand in front of the car while you do this. Be slow and methodical, and be zen about it. Don't worry....its probably something really minor that you'll laugh about when you discover.
Basically, make sure everything electrical is connected, your gear shift is in park, and all of your fuses are working. Make sure your fusible link is properly connected. Check your battery connections - you probably unhooked them for the installation. Then check if all your relays are working. Then download the bentley manual and check the starter troubleshooting list. Its best to get a good nights sleep before you start looking at this again. |
Sometimes might still be loose.
or not as clean as you thought. Did you accidently connect the small wire to the 'cold start' terminal of the solonoid? Been there - done that.
Good - Fast - Cheap: Pick any two. Current: E23 735i; E30 318i; E32 735iL; E38 735iL; R50 Cooper; R55 Cooper Clubman. Previous: E21 318i; E32 735iL; E34 535i; E38 730iL; E53 4.4i
Yup, check connections.
I would check fuses and starter connections.
I would update this thread !
