Old 10-06-2012, 02:58 PM
tturedraider's Avatar
Freedom isn't free!!
Question Why has BMWNA not revised the 2013 328i MPG ratings back to 24/36?
?? Anyone have the inside scoop? It seems a little odd they haven't at least revised the highway mpg rating up an mpg or two. Did they goof it up so bad in the beginning that the EPA was totally correct in their testing?
www.bmwcca.org
Old 10-06-2012, 03:57 PM
justinnum1's Avatar
justinnum1 justinnum1 is offline
Mein Auto: F30 335i mSport
UNless the car computer is wrong, i get anywhere from 36(at 72mph) to 39(at 65mph) on the highway
F30 328i Alpine White/coral red Msport 6MT, HK, Xenons, Msport brakes, black grills and side sills, performance exhaust
Old 10-06-2012, 07:15 PM
Elk Elk is offline
Mein Auto: ~
Unfortunately, we cannot compare steady-state cruising at speed with EPA highway figures. The EPA test protocol for high includes a great amount of speed variation with the concomitant braking and accelerating. This is why everyone in every car does better on the highway than the EPA figure.
Old 10-06-2012, 07:18 PM
justinnum1's Avatar
Fair point.
Loving the efficiency of the N20 tho. Hope the N55 is close.
Old 10-06-2012, 07:46 PM
Elk Elk is offline
Mein Auto: ~
The best I have experienced is 36 MPG @ 70 MPH for 160 miles and 34 MPG on the return trip two hours later. While not as good as the N20, it is closer than I would have predicted.
Old 10-06-2012, 07:51 PM
justinnum1's Avatar
Good to know, thx.
Old 10-06-2012, 08:00 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
i'm averaging 17.5 on an N54 with PPK.... 80/20 city/highway. i can only hope the n20/n55 does better when i get my F30...
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 10-06-2012, 08:09 PM
justinnum1's Avatar
My N54 was a gas guzzler too. 18mpg. My n20 gets 28mpg. Hoping the N55 gets 25.
Old 10-06-2012, 08:16 PM
my 07 6MT RWD got about 21mpg same driving conditions. i think i picked the worse combo, awd +6at
very torn between the n20 and n55
Old 10-06-2012, 08:29 PM
As best as I remember from the EPA video the highway cycle includes mostly steady speeds with no braking.
EDIT: just checked the testing. They do two highway tests now and combine the results somehow, but they don't specify how. They do a steady rate test with no braking and they do a congested freeway type test with four full stops.
www.bmwcca.org
Old 10-06-2012, 08:31 PM
justinnum1's Avatar
Thats a tough one man. The N20 is an awesome motor, provides plenty of power, incredible fuel efficiency and slightly better handling due to reduced weight up front. Dont really think you can go wrong with either engines.
Old 10-06-2012, 08:40 PM
that's exactly my quandry. i've read that the bmw engineers and test drivers say that the N20 and n55 F30 turn in almost identical lap times on a given course-- the N55s are faster in the straights, the N20s are faster in the corners.
tbh, there is very little opportunity to go to full power on my current car in NYC--rather amusing, one of the roads i routinely drive has the lights sync'ed at 21mph. any faster and you hit reds.
Old 10-06-2012, 08:42 PM
justinnum1's Avatar
I think that depends on the course, but it sounds like you would be perfectly fine with a 328i msport, in estoril blue of course
Old 10-06-2012, 09:23 PM
Elk Elk is offline
Mein Auto: ~
Here are the EPA test schedules: clicky.
Old 10-07-2012, 10:07 AM
vern vern is offline
Send a message via AIM to vern
Mein Auto: 01 330ci 05 530i 06 X3
What mode?
cheers
vern
2012 335iA Blk. Sapphire- Sport-Blk. Dakota Leather/Red-Brushed Alum.Trim-DAP-PP-CWP Rear View Camera-BMW Asst w/Enhanced BT&USB-High Gloss Blk.Trim Hghight-PSP-Speed Limit Info-Tech. Pkg-PDC-Rear Manual Sun Shades-SAT-Variable Sport Steering-Wheel Locks- Rubber Mats-Euro Del 5/14/12-Redelivery 7/16/12 2006 X3 3.0iA 4/6 Silver Gray Metallic-Black Leather-Nav-PP-SP-Xenon Headlights-PDC-Heated Front Seats-Privacy Glass-Servotronic Steering-Premium Sound System-R R R- Wheel Locks- Rubber Mats
Old 10-07-2012, 11:14 AM
So, I'm still wondering. Did BMW retest the 328i and end up with the same results the EPA did?
www.bmwcca.org
Old 10-07-2012, 11:19 AM
justinnum1's Avatar
Originally Posted by vern View Post
What mode?
cheers
vern
Eco pro. But I use cruise control so I would get the same in comfort mode.
Old 10-07-2012, 02:10 PM
bmw_or_audi bmw_or_audi is offline
Mein Auto: Passat 1.8T MT
Absolutely. Check out the EPA highway testing speed versus time curve below. Average speed is about 48mph. But consumer Reports does accurate measurements of steaty state highway cruising (I assume at 65mph) and they list 40mpg for the 328 with the 8-speed transmission. That's the beauty of turbocharged engines: when boost is not on, you get the efficiency of a small displacement engine.
Old 10-07-2012, 02:14 PM
I'' take your word for this statement (though obviously things are course dependent), but I wonder whether the 335i is "under-tired" (made up word ). It weighs almost an extra 200lbs - I assume mostly at the front - yet it has the same rather skinny 225mm tires as the 328i. For comparison, the lowest trim S4 has 245s, 255s being optional.
