E30 (1982 - 1993)
Old 10-07-2012, 03:30 AM
Gold Chariot Gold Chariot is offline
Gold Chariot
Mein Auto: 1986 BMW E30 318i
My 1986 318i Automatic Shifter and Clock should be lit up, right?
Just wondering. i think they should and the lights are just out, if so, it should be easy to find out what kind of bulbs to get. Just want to make sure that the Shifter and Clock are meant to be lit up.
Old 10-07-2012, 04:32 PM
BMWFatherFigure's Avatar
Old School
Clock yes; Shifter ? as mine is manual. Check hand book (owner manual). Usually easy swaps.
Current:
E38 Parts Car
Previous:
Old 10-07-2012, 10:07 PM
Gold Chariot
Thanks! Will do, although i dont have a manual. Im sure i can find out from someone.
Old 10-08-2012, 01:27 AM
Old School
Clock (in mine) is a weird small unit with the globe part fixed to a plastic nut type part with metal contacts. Sorry to be so vague but you will understand when you see it. Easy swap. I guess shifter will be a capless globe of some size.
Current:
E38 Parts Car
Previous:
Old 10-08-2012, 04:25 AM
Gold Chariot
Its ok, you arent being vague, To a guy who knows nothing about lights it sounds pretty complex! ;D
Old 10-08-2012, 05:02 AM
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
Are you talking about the auto shift indicator? It is a light usually the wires on that one get buggered. I would pull up on the inside of the shifter housing under the horse hair and pop that off to reveal a few screws, then the cover comes off and you can see the bulb and wires.
Old 10-08-2012, 11:16 PM
Gold Chariot
Yep! Thanks Swiss, although i get nervous pulling on that i feel like its going to break!
But fair enough, will do.
