E36 (1991 - 1999)
Old 10-07-2012, 08:04 AM
doug773 doug773 is offline
Mein Auto: BMW 540, 328 AUDI A8
E36 brake lights system
From time to time I got the message "check brake lights system" for no apparent reason and totally randomic. I've went to the shop, they check everything on the computer and found nothing wrong.
It comes and goes, sometimes on 2, 3 months cicles.
Any clues?
Old 10-07-2012, 08:19 AM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
Probably one of the brake light bulbs has an intermittent contact that only shows up when conditions are perfect, like hitting a bump a certain way. It seems to be correcting itself.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 10-07-2012, 09:59 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Actually, if you have a bulb contact which is iffy, you'll get a bulb out warning. If the brake like switch at the brake pedal is going bad (very common issue in the E36), you will get the brake light check warning. Of course, check all your bulb contacts, but my guess is that your brake light switch is on the way out. Fortunately they're pretty easy and inexpensive to replace.
1998 BMW 328is
1966 Pontiac GTO
Old 10-07-2012, 10:34 AM
Echo46 Echo46 is offline
Mein Auto: 2003 330i and 1995 325i
As Ze conjectured, it is probably your brake light switch, which is located behind your brake. PIA to get to. When you crawl up there, pull the red sleeve all the way out just behind the bracket. Then take needle nose pliers and pinch the switch just in front of the bracket and it should pop out.
Old 10-07-2012, 11:44 AM
Thank you, but...
The interesting thing is that ALL brake lights still work normally even when the message is showing!
And this warning is different from the one that comes when is a bulb is burnt.
Basicly, the warning comes and goes by itself. Sometimes I drive 3 months without any warning. Then it comes. Sometimes is enough to simply turn the car off, take the key out and turn on again, a reset that erases it. Go figure.
Old 10-07-2012, 03:59 PM
EnserioJose's Avatar
EnserioJose EnserioJose is offline
e36 aint noise pollution
Mein Auto: 1996 328is
Try swapping in a new switch. The engineers built redundancy into the brake system so the lights still coming on isn't a telling sign. If they do fail you'll get a "brake light failure" warning.
Before I changed mine I was getting the warning randomly. It seemed to be linked to the humidity??? Or the e36 gods were messing with me.
96 328is preceded by 09 G8 GT... RIP 7/15/2011
Originally Posted by E36 Phantom View Post
We've tried this before and it never has really worked, but good luck bro.
