Old 10-02-2012, 02:01 AM
helm01 helm01 is offline
Mein Auto: BMW 530i
Rear Tail Lamp (LED) replacement - 2003 530i
Where is the best place to get a rear tail lamp bulb (LED) for a 2003 530i (middle strip bulb labeled #2 in the owner's manual diagram)? According to the owner's manual, it's the only bulb in the tail light assembly that is LED. Is it easy to change this bulb? Thanks!
Old 10-02-2012, 06:39 AM
Mein Auto: 01 525i, 01 X5, 91 Z32TT
I have never heard of that bulb replacement before but anything is possible. I'd try the dealer for something small like that.
01 Anthracite 525i Sport, with 01 E53 3.0 and 91 Z32TT
Old 10-02-2012, 10:14 PM
540 M-Sport's Avatar
540 M-Sport 540 M-Sport is online now
Mein Auto: 01' 540 M-Sport cdn, F355
Not user replaceable, you have to buy a new tail light assembly. I would at least tear into it and see if you get lucky and it is only a loose connector or bad cold solder joint first.
You may need to remove the assembly to inspect it. It is held on by a few small nuts removed from the rear.
Factory M-Sport with factory installed M-tech bumpers, factory Bluetooth, factory M-Audio 10" dual voice coil subs, homelink, M5 rear stabilizer bar, Bilstein B14 PSS coil overs, stop tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, strong strut front upper stress bar.
Old 10-06-2012, 03:19 PM
abanjableu's Avatar
abanjableu abanjableu is offline
Mein Auto: 02 540/74 911/01 Z3(hers)
Are you sure it is led
I just had my blub go bad about an hour ago...looked in the trunk to find a little socket that twisted into place with a bulb that twisted into the socket. Just a cheap bulb in there in my 02.
Old 10-06-2012, 03:47 PM
The tail light running light, (when you turn on the headlights or parking lights) is LED. The brake, back up, and turn signal bulbs are all traditional incandescent bulbs. I would assume you were changing a brake light bulb.
Old 10-07-2012, 05:24 PM
abanjableu's Avatar
Yes, it was my third brake light on the rear deck. I didn't know what the #2 bulb from the photo was as the OP didn't post a pic . I know in my z3 the thrid brake light is a sealed unit that does use LED technology which is what had me mixed up I guess.
