Old 11-02-2012, 09:27 PM
edbiology's Avatar
edbiology edbiology is offline
Mein Auto: 2013 X3 28i
Automatic mirror adjusting when backing up...not working?
Hi, my right side mirror used to automatically adjust downward when I back up ( to help me to see the curb I guess), but it no longer does it. Is there somewhere in setting that I accidentally turned off? Please advice, thanks!
Old 11-02-2012, 09:42 PM
SpaceManGray SpaceManGray is offline
Mein Auto: 2011 X3 35i
The switch you use to select the driver or passenger mirror for adjustment, must be slid to the driver side position to activate curb monitoring. Your switch is likely set to control the passenger mirror at the moment.
2011 X3 (F25) xDrive 35i 3.0L, nav, xm
Old 11-02-2012, 09:44 PM
Pro tip: if you hold the interior light button down for 3 seconds (or until the lights turn off) it will prevent your interior lights from coming on when you open a door. Press once to re-enable automatic lights.
Old 11-02-2012, 09:48 PM
edbiology's Avatar
Originally Posted by SpaceManGray View Post
The switch you use to select the driver or passenger mirror for adjustment, must be slide to the driver side position to activate curb monitoring. Your switch is likely set to control the passenger mirror at the moment.
OMG you are awesome. You are right about the switch, and the light tip is very useful!!! Thanks a lot!
