BMW Coding and Programming
Discuss coding options and features on your BMW here. |
Coding 7 series F02 2013?
Hi,
I have 2 questions: 1-I'm wondering If Is it possible to code my 7 series 2013 with PSdZ Data v.47.5? 2-Is It possible to activate the acoustic signal for locking/unlocking through coding? I Have the Alarm system (302) it's already Installed, But this option is not appearing in the IDrive. Thank you in advance, |
2) Should be. Code HU_CIC / ACOUSTICAL_LOCK_CONFIRM = aktiv
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
Thank you Last edited by fahadcom; 10-08-2012 at 12:14 PM. |
Now the Module is "HU_CIC" right ? what about the Section ? Could u tell me what is the section? Thank you, Last edited by fahadcom; 10-15-2012 at 02:32 AM. |
It much easier to just use the search window at the top, and paste the value (ACOUSTICAL_LOCK_CONFIRM) into it. It searches Top Down though, so make sure you highlight the very first entry in the ECU before searching, and DO NOT include any trailing spaces after the value.
These things differ some by chassis, so if you can't find "ACOUSTICAL_LOCK_CONFIRM" exactly, trying searching only on "ACOUSTICAL" or "LOCK", etc.
You know. I Tried to activate the acoustic signal for locking/unlocking through my dealer but they replay to me with this.
================ customercare.me@bmw.com Oct 3 (12 days ago) to me, frank.zauner Dear Mr. Alibrahim, Thank you for your email which was forwarded to us from BMW in Munich. Kindly be informed that the Acoustic signal for locking and unlocking cannot be retrofitted. The video shows that the car is from the US market where this system is available but not in the European market. The alarm system mentioned in your email is an anti theft alarm. In the European specification, only the visual indication for locking and unlocking is available. If you have any further enquiries, please do not hesitate to contact us. With kind regards, Jaxeena Mahesh ---------------------------------------------- BMW Group Middle East Jaxeena Mahesh Customer Care Phone: +971-4-3132-651 Fax: +971-4-3300-126 mailto: customercare.me@bmw.com Url: http://www.bmw-me.com ---------------------------------------------- =================================== Hope that's I can activate this option through coding
Yes I'm sure, I have the Alarm system "anti theft alarm" Code (S302A). And it's working. But the option for acoustic signal for locking/unlocking is not showing in the IDrive
Then you should be good to go.
Finally I activated the acoustic signal for locking/unlocking successfully, But the sound signal is coming only from the right corner of the rear bumper. In fact I don't know if it's normal or not.
![]() I also successfully coded: 1-Disable seat belt reminder - driver. 2-Sets car's Auto Start/Stop function to start in the last used setting. 3-Speed limit information. 4-Disable TV and DVD Speedlock. Thank you shawnsheridan Last edited by fahadcom; 10-23-2012 at 02:21 AM. |
how did you get the acc. signal coded? with "ACOUSTICAL_LOCK_CONFIRM" ? because i had to code: FZD/3002/Akkustische Quittierung Schaerfen FZD/3002/Akkustische Quittierung Schaerfen mit Klappenbetrachtung FZD/3002/Akkustische Quittierung Entschaerfung FZD/3002/Lautstaerke Akk. Quitt. tageszeitabhaengig Regards
2010 BMW 535d GT |
strange... what are your values then in the settings above? in the CAFD of FZD?
Is your checkbox now functional?
2010 BMW 535d GT |
NO it's not in CAFD of FZD, As i remember it was on HU_BNT or something like that "use the search window" , Any way I will check for you tomorrow, sorry ....
Be sure that you have the Alarm system "anti theft alarm" Code (S302A). If you don't know check out this web: http://bmwvin.com/ Last edited by fahadcom; 10-23-2012 at 01:06 AM. |
dear fahadcom
my signal is working, but i did code it with these settings to set "aktiv": FZD/3002/Akkustische Quittierung Schaerfen FZD/3002/Akkustische Quittierung Schaerfen mit Klappenbetrachtung FZD/3002/Akkustische Quittierung Entschaerfung FZD/3002/Lautstaerke Akk. Quitt. tageszeitabhaengig the "ACOUSTICAL_LOCK_CONFIRM" is just the checkbox in the CIC. Which i also coded now and really good to have, for some reasons when you have to shut of the signal. my question was, what are your entries in FZD to see if these settings have to be on "aktiv" or not for the signal functionality. Thank you.
2010 BMW 535d GT |
Actually I don't know what you mean by FZD, because I'm new in coding. But what i did I brows "HU_BNT" then search for "ACOUSTICAL_LOCK_CONFIRM" then chose edit then I chose "aktiv" after saveing this setting, I started the Idrive I put a check mark on acoustic signal for locking/unlocking. That's it
what i mean is:
In the ECU "FZD" there are these settings: FZD/3002/Akkustische Quittierung Schaerfen FZD/3002/Akkustische Quittierung Schaerfen mit Klappenbetrachtung FZD/3002/Akkustische Quittierung Entschaerfung FZD/3002/Lautstaerke Akk. Quitt. tageszeitabhaengig what would be nice to know is, if the settings were already on status "aktiv" or if they are "nicht aktiv" but the singal works anyway.
2010 BMW 535d GT |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
