Old 10-08-2012, 01:49 PM
E39swagwag E39swagwag is offline
Mein Auto: 13 Audi A6
High Mileage synthetic oils
Do they really make a difference and why? I'm on a 5k oil change interval, and I'm burning about 3 quarts now between changes. No signs of leaks. 172k mi, 525it.
02 525iT sport M pkg
01 Z3 2.5
13 Audi A6
12 Acura MDX advance
Old 10-08-2012, 03:02 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
A little excessive, but not terribly: the six is an oil burner.
I've not seen high-mileage "synthetic" oils. Might try a fill. Report back.
Might also check your crankcase vent system for failure. A bad CCV will cause high oil consumption. Search here for diagnostics.
Old 10-08-2012, 03:26 PM
AH673000 AH673000 is offline
Mein Auto: 1997 BMW 528i
My 528i burns one quart in 6k @ 120 k miles on Mobil 1 .
I do use Mobil 1 extended mileage oil ( has additional additives to go 15k between changes) in my 140k Jeep v8 .... Burns 1 quart in 10k .
I also use the extended mileage in my wife's Miata with 80k .... It is an oil burner @ 1 quart every 2 k .
All cars are original owner vehicles with documented oil changes since new. All grew up on Mobil 1. All will go 200k before they get the pink slip . Our last Miata ( '90) went 260k on Mobil 1. No engine issues so far. Makes me a believer .... Mobil 1 extended ( gold bottle) and Wix / Purolator filters ..... Cheap insurance .
Old 10-09-2012, 05:48 AM
Chisum Chisum is offline
Mein Auto: 2003 525i 2002 525iT 5sp
I user Mobil 1 extended on my 2003 525i with Mann filter. I change the oil every 7k miles. I'm at 93K miles now and the car does not burn any oil.
Chisum
Old 10-09-2012, 07:28 AM
tmvE39/E53/Z32's Avatar
tmvE39/E53/Z32 tmvE39/E53/Z32 is offline
Mein Auto: Dinan //M5, Dinan 4.8iS,
My M54 engine burns 1Qt between oil change. I've just tried High-Mileage Mobile1 Synthetic 5W-30 for the last oil change. Will see how it does.
2000 Dinan S1 //M5 (my DD), 06 DINAN E53 4.8iS (wife's DD), 90 Straman Z32TT (my pride & joy ride)
Gone, but not forgotten: 01 E53 3.0i, 01 525i Sport, 03 DINAN 540i MSport, 01 //M5 and 91 Z32TT
FS E39 Hella Celis Euro taillights WITH ballasts, for pre-facelift update.
FS OEM E53 X5 Tow Hitch http://www.bimmerfest.com/forums/sho...49#post9981849
Old 10-09-2012, 07:35 AM
cn90 cn90 is offline
An M54 engine with 175K miles, not so high miles.
Have you done the PCV system yet?
Old 10-09-2012, 12:38 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Ooooh goody. Another oil thread! Yippee!
To the OP, see this:
- All you want to know about BMW motor oil petrology (1)
Old 10-09-2012, 07:27 PM
josemedeiros007 josemedeiros007 is offline
Mein Auto: 1998 528i 4Dr
May I suggest using a thicker weight oil to compensate for wear? A thicker weight oil, such as Mobile 1 15w50, should reduce oil consumption between oil changes unless it's a faulty CCV, stuck ring due excess carbon deposits, or bad valve seals, from what I read online.
http://www.mobiloil.com/USA-English/...duct_Guide.pdf
A leak down test should be able to determine which cylinder's may have a piston ring issue. You may want to also try using product like Seafoam, B12 Chemtool to desludge your engine prior to changing the oil, this may help clean out the CCV.
Bavuto.com sells a LubriMolly flush and fuel injection kit you may also want to try.
http://blog.bavauto.com/12170/bmw-an...nd-protection/
Last edited by josemedeiros007; 10-09-2012 at 07:34 PM. Reason: Spelling correction
Old 10-10-2012, 10:23 AM
DHoang's Avatar
DHoang DHoang is offline
Gearhead
Mein Auto: '98 528i, '82 323i
Like many here are saying, definitely service your CCV/PVC system.
3 yrs ago, my 528 was using up about 2 qts in between a 5k mile oci.
I replaced my CCV, cleaned out the ICV w/ carb cleaner to free up the ball valve, and replaced all hoses surrounding the CCV, including the hose that attaches to the oil dipstick tube and oil pan.
Since then, the oil consumption has disappeared completely. Went from burning up 2 qts every 5k miles to zero oil consumption since doing this. 20k miles so far and no oil loss. 0w-40 mobil 1.
http://www.bimmerfest.com/forums/picture.php?albumid=4132&pictureid=24642
