Old 09-09-2012, 07:53 PM
amt7565 amt7565 is offline
Send a message via Yahoo to amt7565
Mein Auto: 2005 330i
Indicator lights going out often
I have changed my Front right and left indicator bulbs a few times this past year. I purchased the bulbs from Autozone. Anyone might know why they keep going out often? Is it inferior Sylvania bulbs I buy from Autozone?
Regards
AMT
2013 X5 White| Base Model|
Old 09-10-2012, 04:44 PM
HarryR325i HarryR325i is offline
Mein Auto: 2002 BMW 325I
If it were the rear lights I'd say maybe it's due to the faulty ground wire in the harness. There's a recall in effect to replace the rear light assembly on E46's. Not sure about your front indicators. probably not faulty bulbs (how likely would that be?)
Old 09-10-2012, 07:04 PM
QAfred QAfred is offline
Mein Auto: 328i, 330ci, R1200C
It's more than likely the connectors. # 3 on attached (Check your voltage output too. Make sure it is a consistent 13.6 to 14.0 when running and voltage is not jumping all over the place).
I have had this experience too on both of my e-46's. I have had to replace all 4 of the connectors because the bulbs kept blowing. No problem afterward.
About $15. I remember going to the dealer and with my 15% discount (CCA member) they were a little cheaper than that for my year-about 5 years ago anyway.... http://www.pelicanparts.com/cgi-bin/...FILTER_BMWM=ON
Old 09-10-2012, 07:56 PM
This looks about right. I did notice that the connectors were rusted off. Appreciate you posting the links and diagram.
Thank you
Regards
AMT
Old 09-10-2012, 07:58 PM
alpinweiss alpinweiss is offline
Mein Auto: E46, E83, E90 (all MT)
Start by replacing your bulbs with genuine BMW bulbs. They cost a bit more than the discount bulbs, but it is a far cheaper solution than replacing any other part.
BMW's are very hard on light bulbs, and often the cheaper ones do not hold up. Many BMW bulbs are single filament, and use a low voltage (for dim illumination), and a high voltage (for bright illumination). I am not sure about the bulbs on your specific car.
If this does not solve your problem, then look at sockets and connectors.
Alpinwei▀
E46, E83, E90 (all with three pedals)
F25
BMW CCA member
Old 10-25-2012, 10:26 AM
Thank you. Just saw this, will definitely get the BMW lights next tiime around.
Regards
AMT
Old 10-25-2012, 10:35 AM
jdauria jdauria is offline
Mein Auto: E39 ///M5
This happens to mine quite often as well. Front left indicator.
I usually just pop out the corner, take out the bulb and put it back in, and it works again for alittle. I heard getting a new socket does the trick (Only $9-13), so that's my next investment. Taking out the corner takes literally 2 seconds
2000 ///M5 ///M Registry (09/99 Build)
Oxford Green Metallic II (430) | Caramel Nappa Leather (M3CR) | BMW Individual Black Birch |
Tuning Tech Tune by Frank Smith (http://www.tuningtechfs.com/)
Supersprint Headers
SuperSprint X-Pipe
Storm Motorwerks Products
2003 X5 4.6iS | Black Sapphire Metallic | Black Sport
2006 X3 3.0i M-Sport | Silver Grey | Terracotta | AT | Navigation | Premium Pkg | Cold Weather Pkg | AFE |
