Old 10-08-2012, 03:14 PM
bimmerbertha bimmerbertha is offline
Mein Auto: e39
Exclamation 97 e39 circle with teeth and exclamation point inside the circle.
since I've owned my e39, I've always had this problem. when I start the car, a light on the dash comes up, it's a circle with teeth and and exclamation point in side the circle. I have to restart the car a couple of times until the light goes off the dash board. it doesn't always come on, but most of the time it does.
I have no clue what it is or what it is telling me, I don't have an owner's manual.
could anyone tell me what it's telling me or what I need to do?
Old 10-08-2012, 03:30 PM
Coochie_Bandit's Avatar
Coochie_Bandit Coochie_Bandit is offline
Mein Auto: 540
Lmao @ circle with teeth.
Its your traction control.
Old 10-08-2012, 03:43 PM
Mein Auto: e39
no, it's not that, the circle is on the far right of the dash.
Old 10-08-2012, 04:27 PM
johnstern's Avatar
johnstern johnstern is offline
Mein Auto: 2000 BMW 528iT/5, S/C
That is the warning light for your automatic transmission or to quote the owner's manual-
"Automatic transmission* Because of a malfunction, the automatic transmission shifts only in the emergency program. Please consult the nearest authorized BMW center. For additional information: Refer to pages 73, 76."
Owner's manual is available online.
http://www.e38.org/2000Manual-5Sedan-SportWagon.pdf
Old 10-08-2012, 04:50 PM
bkgreene39's Avatar
bkgreene39 bkgreene39 is offline
Mein Auto: 1998 BMW 528i
+1 to the above stating its the transmission. How many miles on the transmission?
Old 10-08-2012, 05:09 PM
Mein Auto: e39
it has 168k miles on it
Old 10-08-2012, 05:20 PM
Mikes530 Mikes530 is offline
Mein Auto: 530
Is your transmission shifting normally? Any unusual noises or vibrations? Does it move through all the gears up and down?
Old 10-08-2012, 05:24 PM
Mein Auto: e39
the transmission shifts normally, but now that you mention it! yes, i have felt vibrations especially when I'm at a stop or driving slowly out of my drive way, it gives off a couple of random vibrations.
all the gears are okay though.
Old 10-08-2012, 05:47 PM
bkgreene39's Avatar
Get the code(s) read then start from there. I believe you have the GM 4L30-E transmission. Sometimes transmission errors can occur due to electrical related issues as well so it might not be the transmission. Start with the codes.
Old 10-08-2012, 06:31 PM
Mein Auto: 530
+1 on getting the codes read. If your transmission is behaving normally it's possible that you might just have an electrical fault as bkgreene mentioned. But to be safe have the codes read and you'll know for sure.
board, dash, e39, light, problem
